68_GT said:considering worst case scenario here if I needed an engine here what would you guys do ?
thinking to get a used complete engine out of a wrecked car or get a deal on a new Ford engine assembly ? maybe an upgrade engine with Ford racing ?? sheez.... My dealer wanted $5k for a long block and $10k for a whole new engine.
68_GT said:I just talked to Tousley Ford and they say a new engine is $4600 discounted to $3,700 for the good guy discount. New engine is basically a long block. Apparently they don't have a fully dressed SHO replacement engine. Do those come from Ford Racing ? Maybe only for a F150. Would that work just need to use our upper intake ??
here is a demo of the HFPF I think ??
https://www.youtube.com/watch?v=WdYDRXsG6Qc
glock-coma said:I remember in shop class to find the cylinder that's knocking you remove the plug wires one at a time and listen. If the knock gets quieter when the wire is removed that's your bad cylinder. Removing the wire stops the combustion pressure on that cylinder.
Not sure if you can still troubleshoot a di motor like that.
Plug wire is only disconnected for a few seconds.pmezo33 said:glock-coma said:I remember in shop class to find the cylinder that's knocking you remove the plug wires one at a time and listen. If the knock gets quieter when the wire is removed that's your bad cylinder. Removing the wire stops the combustion pressure on that cylinder.
Wouldn't that cause the injector to continue to spray while not getting any spark? Not sure I'd want to take that risk. Might cause fuel damage to the cats.
