geophb said:Yikes! Live in rust belt?
Hows loose is your rear turbo wastegate flapper without the arm connected if you dont mind? Mine is rattling, just tryin to compare.
Southeast Minnesota so you betcha on the rust belt! Luckily this is not my vehicle.
It is loose but not significantly. Same with the exhaust wheel on the turbo. But it is obviously bad. Should be dropping the turbos this weekend.
