2013 taurus sho hole in transfer case
No writeup for the 2013+ yet.  The PP has cooling and temp monitoring, must have failed somewhere along there.
OP, I see now that you mentioned in an earlier post that your SHO is not equipped with the Performance Package.
Only the PP PTU has a temp sensor, right?
So, it is likely that there wasn't any aux cooling to save the bearings, and no sensor to trip a dummy light.
@SHOdded, there IS a write up out there for non PP cars, right?
Seems more and more like servicing the PTU is becoming an imperative maintenance item, particularly on non PP (or pre 13 PP?) equipped SHOs.
Still something I am unsure about - did the pre 13 PPs have the aux cooling on the PTUs? Or is that just 13+?
May be right. That's pretty sad, seeing as there hasn't been any success swapping in fresh fluid on the PP 13 plus.
I guess I'll finally have to break down, dig in and figure something out. No pun intended.
