Hybrid trunk-mounted meth system
Update: I did this a while ago, just finally getting around to posting it.  I finished the trunk cover.  It fits pretty well, but as you can see the fabric color doesn't match exactly.  I made a support using a M8x1.25 threaded rod & a rod coupler, to fit on top of the factory rod.
I also found that it was difficult to see the green LED in daylight, so I installed a DPDT On-On switch, so that I can reverse the red & green indicators.  The way I have it now, green indicates the pump building pressure, red indicates spraying.  Much easier to see the red in daylight.  A flip of the switch changes it back to "normal."
The bulkhead fitting link is linking to a checkvalve above it, do you have the right url for that part?
What length AN hose did you purchase from trunk to front? I'm going to do the same setup, not sure which length exactly. What would you recommend?
What do you run, 33%, 50/50, 100%?
