Aeroforce Gauges for your Ecoboost vehicle
I saw a single pod that was universal and mounted near the base of the A pillar near the windshield.  I liked it, but it was 105 bucks.  I don't have any issue paying that kind of money for the pod, but was just uncertain of the quality.  Todd, any single pod/column mount suggestions?  I want column mount or near the windshield/A pillar.  I know nobody is going to mkake one for the MKS (because they will sell 2 of them maximum) - so universal is what I am searching.  As soon as I find a pod, I am ordering the gauge from you.
I know Chris & I have discussed it, but was unfeasible for him to do. & TSS the one that I saw that was a dual pod A pillar was the black one that Storm used to modify it to work on his before he sold it. The problem is both Chris & I & most likely you want is something to match the fabric that was there & not look like it was just stuck on but more like Chris center pod & now now Todd's pod that add the extra gauges without disturbing the aesthics of the car. I'm very interested as want to add oil pressure gauge & one other gauge for sure to my car. Other than that a column pod maybe the only choice.
mikev
mikev
bpd Mike had his A pillar and the mounted pod leather wrapped… looks good.  If the cloth couldn't be easily matched I bet either leather or perhaps a vinyl to match the dash.  If you did the wrap on both A pillars there wouldn't be any aesthetic asymmetry. If cloth is the main desire and it's not available to you retail I bet you could cut the headliner out of a wrecked car and use that.
I am actually not worried about color matching.  SEM Leather Dye and Vinyl dye and  Fabric Dye is great stuff i have used many times.  You can get it (and color charts) from most Auto Body Shop Suppliers.  I already have a can for the MKS that I would be satisfied with IF I decided to paint it. .
Also, my dash is black anyway, so if something sat in the dash tucked way up near the a pillar/windshield intersection, I would likely be okay if it was black.  BUT, I only want one pod.  AND,  I want the gauge pod to be small and discreet and blend in.
Agreed about color and changing… I was talking about matching the texture of the material used for the pillar wrap.
I will be anxious to see what you come up with for your MKS.  I am interested in the same thing you are but do not see a very good place to mount it.  I thought about that wasted space in the console where it says LINCOLN, but that is too far out of sight and I don't really want to mess with taking that panel off.
^^ thought of that too - but not discreet and low profile enough for me....and I don't like vent pods - they look tacky to me.
I am trying to find a rear view of the gauge so I know where the OB2 input attaches to the gauge as I ponder install idea.  Does it enter from the bottom? Backside?  How big is the connector (to the gauge itself).  Any non front facing  photo would help! Thanks!
Here ya go
Not that I know of at this time.  We're thinking about buying a 3D printer to do custom pods like this but we're not there yet.
I was looking at pics of your dash and there looks to be a center dash speaker cover similar to the SHO, this dual pod would probably fit there as well as on my SHO.
Todd
Todd the guys are busting my ass that I don't have a way to mount the dual guages like you did on your car.
Let's figure out a way too get these set up for Flex/SHO/Explorer Sport
I was asked to tell you guys how I did the steering column dual pod shown in the youtube video.  It was very easy but looked pretty good I thought.  I used 2 Autometer angle rings:
I ground a flat spot on the large end on both rings.
I attached to the steering column using 3M tape.
The cables were easy to hide around and under the steering column.  Finished product looked like this:
Or watch the video for better perspective.
Todd
If you're interested on the dual dash pod, we happen to be sold out but will have more next week.
To give you an idea or what's involved in the install here are the steps:
1.  Remove speaker cover.  It has 5 clips that pop off easily with a vinyl pry tool.
2.  Drill hole to the left of speaker assembly big enough for whatever wires are needed.
3.  Remove speaker to make it easier to route wires using a fish tape or coat hanger or whatever you use from driver foot well.  Once wire are routed run them through hole drilled in step 2.
4.  Replace speaker.
5.  Drill (2) 1/4" holes in speaker cover to mount pod.  Template will be provided.  Pod has two clips that will snap into these holes.
6.  There will be a small gap between the back most part of the pod and the speaker cover unless you epoxy the back side to the cover, I used a c-clamp and some generic brand of epoxy putty which cures quick.  You don't really notice this gap once everything is installed but I'm a perfectionist.
7.  Drill a hole in speaker cover on bottom left side where it will be hidden by pod.  This is where gauge wires will go.
7.  Run wires through this hole and snap speaker cover/pod back into dash.
8.  Run the gauge wires to the two pod openings, and install gauges.
That's it!
Todd
I have compared the SHO and MKS center speaker cover area and unfortunately, in person they are very different.  I truly appreciate you taking the time to look it up though.
BUT....that column mod (the easy one) might be an idea and I also am thinking about the sunglass holder too - but I actually use that for sunglasses....
S/ Another "Todd"
Sorry one more question.  I know the gauge can display boost with our vehicles, has anybody confirmed that MPH can be displayed too?  Todd, the website indictaes "may" be able to display depending on vehicle - or something like that.  I am a hair away from ordering if I know I can have boost number on top and MPH on the bottom......
