After running my still stock car for a few days after getting it back from having the leak fixed I noticed it felt slower...not slow but not like it should. I checked the LOR thinking maybe they reset the computer but that was fine at -1. I then looked at my other Torque gauges and realized the Max boost the car had seen over the last two days was about 5 psi. I immediately thought that was odd because I know I had floored it earlier. I scanned it with torque and it said no DTCs but the PID that reads how many DTCs said one was set. I fired up FORSCAN and it immediately pulled a P0299 which is an underboost condition. Great... I thought. I checked all the piping and clamps but couldn't really find anything. I reset it and took it for a drive but same behavior and the code came right back. Popped the hood again and noticed the nut holding the top charge pipe was missing but whole annoying didn't see how that could be my problem. I started checking for loose connectors and then I saw a small connector hanging down and it was pretty clear it was unplugged. I honestly don't know now what this sensor is called but I think it compares boost levels from the intake and the manifold or maybe does something to the wastegate ultimately?? (Anyone know for sure) its the one in this pic with all the small hoses and clamps coming out of it right up front. (Not the MAP sensor you swap out for a tune).
Once I plugged it in and cleared the codes it ran great and all my boost is back! I've had great service from this dealer in the past so maybe I just got a bad tech...yikes.
Somewhere out there there is a stock Dodge Charger R/T that thinks his car is way faster than my SHO (happened earlier in the day which is what got me wondering if something was wrong). I want a rematch!
