M MTaurusSHO New member Jan 22, 2017 #1 Looking to install the OEM PP transmission cooler on my 2013.
S SHOdded Moderator Staff member Jan 23, 2017 #2 None that I am aware of. There are a couple of writeups in the HOWTO section for trans cooler stuff, albeit primarily for 2010-12. You could try simply replacing the thermostatic valve for some improvement right off like Colorado-SHOBro did. http://www.ecoboostperformanceforum.com/index.php/topic,522.0.html If you have ACC, putting on the full system might be an issue, but this is how polskifacet did it: http://www.ecoboostperformanceforum.com/index.php/topic,5389.0.html Do you intend to track the car, or does your car sit in traffic all the time, or ...?
8 8nutz8 New member Jan 23, 2017 #3 i got the pp trans cooler(just the front heat exchanger,not the lines cuz i won't use them being i have ACC) from car-parts.com for $50 shipped. mine came off a PI sedan Sent from my iPhone using Tapatalk
B BlueSHO Member Jan 25, 2017 #4 Not sure if this link works here but here is all the stuff you need.. http://parts.autonationfordwhitebearlake.com/auto-parts/2014/ford/police-interceptor-sedan/base-trim/3-7l-v6-gas-engine/cooling-system-cat/trans-oil-cooler-scat
