nickstewartroc
For lack of a better place to post...
SammyB and I are trying to figure out how to get PP *software* features on our non-pp SHO's. What I know up to this point: Someone has already managed at one point to flash the data from a PP to a non-PP and gain the full traction control off button features as well as the steering calibration. I know that you need some sort of programming device, whether it be an IDS type device or pass through device. I found you can get as-built data according to your vin from: https://www.motorcraftservice.com/vdirs/SPubs/default.asp?pageid=spubs_as_call (Make sure to disable your pop-up blocker, otherwise when you click the button it won't do anything!) I have attached the as-built from my 2011 non-pp SHO as well as a 2011 with PP
EDIT: I have also uploaded an HTML file of a compare between the two as-built data files (It's in a zip since I can't upload an HTML file here)
