20ecoboost10
I got the BOV caps yesterdayJosephm said:I just got mine today as well so I have extras if anyone is interested
Thanks again
southtxSHO said:Ok so the pics of the how to are gone . Any links where I can find how to do this VTA ?
BiGMaC said:southtxSHO said:Ok so the pics of the how to are gone . Any links where I can find how to do this VTA ?
Just remove the hose that goes from each BoV to the CAC (turbo intake tube)... Be sure to cap the nipples left on the CAC.... Hi temp is the only requirement for the caps... I used silicon... others have had great luck with chair leg caps etc.
Really it's that easy... the rear one is hard to reach, but it's basically 4 hose clamps removed and 2 nipples capped. There are some pics in my hotpipe install thread that may help. It's here: http://www.ecoboostperformanceforum.com/index.php/topic,2248.msg32460.html#msg32460
Hope this helps.
Same here... Did mine due to hotpipes. Used to go pfffft.... Now goes PFFFFT!Spartn27 said:With my intake system my VTA is pretty noticeable to the point where other drivers notice, the tune made it much more effortless to replicate at my disposal.
The pita part is putting back that rear hose,next time just remove one section and cap off the port,easier that way if you need to put it back down the road for dealer service,good luck.peppelepugh said:Just finished my BOV to VTA last night. Took about 45min due to lack of the right tool to get the hose off the back BOV. BUT, with much fiddling, swearing, and 1 cut knuckle.... my car goes PPPPFFFFFFTTTTTTTT!!!!!! just waiting to see how bad my gas mileage is because every time it goes, i giggle and smile like a 2 year old....
ZSHO said:The pita part is putting back that rear hose,next time just remove one section and cap off the port,easier that way if you need to put it back down the road for dealer service,good luck.peppelepugh said:Just finished my BOV to VTA last night. Took about 45min due to lack of the right tool to get the hose off the back BOV. BUT, with much fiddling, swearing, and 1 cut knuckle.... my car goes PPPPFFFFFFTTTTTTTT!!!!!! just waiting to see how bad my gas mileage is because every time it goes, i giggle and smile like a 2 year old....
While anything could happen... I had a valve cover gasket leak and had the dealer replace it with my hotpipes in place.... No hose to reconnect they had to R&R the charge system to do it. The dealer got it back perfectly and called it "air in - air out" change with no problem.... Again, anything could happenpeppelepugh said:ZSHO said:The pita part is putting back that rear hose,next time just remove one section and cap off the port,easier that way if you need to put it back down the road for dealer service,good luck.peppelepugh said:Just finished my BOV to VTA last night. Took about 45min due to lack of the right tool to get the hose off the back BOV. BUT, with much fiddling, swearing, and 1 cut knuckle.... my car goes PPPPFFFFFFTTTTTTTT!!!!!! just waiting to see how bad my gas mileage is because every time it goes, i giggle and smile like a 2 year old....
*SHOOTING SELF IN FOOT* thankfully i just had my 50k checkup last week and won't need to go back for a while, knock on wood...
