SHOdded said:Any changes to/any work on your engine lately? I'd start by reading this:
http://www.obd-codes.com/p0130
The possible reasons stated are:
Usually the cause of P0130 is a bad oxygen sensor, however this isn't always the case. If your o2 sensors haven't been replaced and they are old, it's a good bet that the sensor is the problem. But, It could be caused by any of the following:
• Water or corrosion in the connector
•Loose terminals in the connector
•Wiring burnt on exhaust components
• Open or short in the wiring due to rubbing on engine components
• Holes in exhaust allowing unmetered oxygen into exhaust system
• Unmetered vacuum leak at the engine
• Bad o2 sensor
• Bad PCM
SHOdded said:AFAIK, it is NTK.
It is on the passenger side down pipe above the plastic shield that closes the engine compartment.moem1090 said:Where is the location of bank 1 sensor 1? By the oil filter?
BiGMaC said:SHOdded said:From RockAuto:
MOTORCRAFT Part # DY1064 {#7T4Z9F472A} Heated
Upstream Front; 7T4F-9F472-AA; Excludes California & Green State Requirements
MOTORCRAFT Part # DY1111 {#8F9Z9F472A} Heated
Upstream; 8F9A-9Y460-AB; California - Green State Requirements
MOTORCRAFT Part # DY1056 {#5F9Z9G444AB} Heated
Downstream (Only 2 Remaining)It is on the passenger side down pipe above the plastic shield that closes the engine compartment.moem1090 said:Where is the location of bank 1 sensor 1? By the oil filter?
And ramps, lift, or pit...SHOdded said:Upstream/upper is sensor 1, downstream/lower is sensor 2. Bank 1 is firewall side, Bank 2 is radiator side. Would seem that bellypan removal is all that is required for access, but IDK for sure.
BiGMaC said:How many miles on your car? Maybe they are just dirty... Takes a blow torch to clean them ....
