"Complete" List of TSB's for your 2010-2012 SHO
TSB 14-0023  HEADLINER DROPPING DOWN AND/OR LOOSE AT REAR WINDOW GLASS
TSB 14-0057  ALL WHEEL DRIVE – FLUID LEAK FROM REAR DIFFERENTIAL VENT CAP – TEMPERATURES BELOW 0 DEGREES C (32 DEGREES F)
TSB 14-0130  EXHAUST ODOR IN VEHICLE
TSB 14-0132  EASY FUEL CAPLESS-CONCERNS WITH FUEL NOZZLE INSERTION OR REMOVAL
TSB 14-0186  Ting, Pop or Click Noise From the Front Wheel Area When Accelerating From a Stop, on Turns or When Shifting Between Drive/Reverse and/or Reverse/Drive
TSB 14-0198  EXHAUST – SULFUR ODOR AFTER HARD ACCELERATION
TSB 14-0223  2.0L GTDI – LACK OF POWER – DTC P2111, P2101 AND/OR P2112 – AMBIENT TEMPERATURES BELOW 0 DEGREES CELSIUS (32 DEGREES FAHRENHEIT) BUILT ON OR BEFORE 10/5/2014
TSB 14-0231  MYFORD TOUCH – concerns with navigation, voice recognition, call sound quality, phone pairing, clock, media, WiFi pass code entry, rear view camera guidelines, no Russian language package and/or poor system performance
TSB 15-0003  3.5L GTDI – FUEL ODOR FROM ENGINE OIL AND/OR ENGINE OIL LEVEL OVERFULL
TSB 15-0047  SHIFT TO PARK OR TRANSMISSION NOT IN PARK MESSAGE – DISCHARGED BATTERY DUE TO SHIFT TO PARK LIGHT ON / UNABLE TO REMOVE IKT
TSB 15-0086  3.5L GTDI – EXCESSIVE OIL CONSUMPTION AND/OR SMOKE FROM THE EXHAUST AT IDLE DURING NORMAL ENGINE OPERATING TEMPERATURE – ALUMINUM VALVE COVER
15S18/15V340/15V340000:  Loss of Electric Power Steering Assist
TSB 15-0105
3.5L GTDI – INOPERATIVE, EXCESSIVELY NOISY VACUUM PUMP, HARD BRAKE PEDAL ON INITIAL START-UP AND/OR OPEN FUSE F64 IN THE BATTERY JUNCTION BOX
Publication Date: June 22, 2015
FORD: 2011-2012 F-150
ISSUE:
Some 2011-2012 F-150 vehicles equipped with a 3.5L gasoline turbocharged direct injection (GTDI) engine may exhibit a hard brake pedal on initial start-up, an electric vacuum pump that is inoperative or excessively noisy and/or fuse F64 is open in the battery junction box (BJB).
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1.Does the vacuum pump operate?
  a.Yes – proceed to Step 2.
  b.No – proceed to Step 3.
2.Is the vacuum pump excessively noisy?
  a.Yes – proceed to Step 7.
  b.No – this procedure does not apply, refer to Workshop Manual (WSM), Section 206-00 for normal diagnosis.
3.Inspect fuse F64 in the BJB. Is the fuse open?
  a.Yes – replace the fuse and proceed to Step 4.
  b.No – proceed to Step 4.
4.Check for battery voltage at the vacuum pump connector C1560 pin 1 with the ignition key in the run position. Is battery voltage present?
  a.Yes – proceed to Step 5.
  b.No – this procedure does not apply. Repair the voltage supply circuit. Refer to the Wiring Diagram, Cell 42-1.
5.Disconnect the vacuum pump connector C1560. Check the resistance to ground at the harness connector pin 2 with the ignition key off. Is the resistance less than 5 ohms?
  a.Yes – proceed to Step 6.
  b.No – this procedure does not apply. Repair the ground circuit. Refer to the Wiring Diagram, Cell 5-1.
6.Inspect pins 1 and 2 in C1560. Are both pins clean and tight?
  b.No – this procedure does not apply. Repair the wiring harness. Refer to the Wiring Diagram Cell 5-1.
7.Replace the vacuum pump and install the harness kit. Refer to WSM, Section 206-07 and the instructions provided in the harness kit.
PART NUMBER  PART NAME
CL3Z-9C490-D    Vacuum Pump Harness Kit
BL3Z-2A451-A    Vacuum Pump
OPERATION    DESCRIPTION    TIME
150105A 2011-2012 F-150 3.5L EcoBoost: Diagnose And Replace The Brake Vacuum Pump Includes Time To Install Harness Kit (Do Not Use With Any Other Labor Operations) 1.0 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO.    CONDITION CODE
9C490                    42
manu:
thanks again for update. that slip tranny issue that larry still has & will not be fixed by the tsb & in my case made it worst which was a mixed blessing as force them to change the 2 sensors.
Turbine Shaft Speed (TSS) Sensor
This Turbine Shaft Speed (TSS) sensor is a Hall-effect pickup that sends a signal to the PCM that indicates transaxle turbine shaft input speed. The TSS sensor provides converter turbine speed information for TCC strategy. Also used in determining static LPC pressure settings.
Output Shaft Speed (OSS) Sensor
The Output Shaft Speed (OSS) sensor is a Hall-effect pickup, located on the transfer shaft drive gear, that sends a signal to the PCM to indicate transmission output speed. The OSS is used for TCC control and shift scheduling
good luck trying to get them to fix it until you can make it happen with tech in car w/ tech laptop hooked to obd port.
but no trouble since they put new sensors in is the good thing
Glad to hear it, Mike!  Too bad these gremlins are so hard to pin down, but electronics are often like that ...
I think this site is maintaining an active and current list of all TSB and recall notices. The latest power steering recall for my 2011 which was announced couple months ago on list.
If you change year in address bar you can search any year Taurus and further change allows search for other vehicles as well.
http://www.fordproblems.com/tsbs/Taurus/2011/
Not an official 3.5EB transverse-related TSB, but since so much interest has been shown ...
TSB 15-0044 3.5L GTDI – DTC P0016 – PRIMARY TIMING CHAIN WEAR – BUILT ON OR BEFORE 10/10/2014
Malfunction Indicator Lamp (MIL) Illuminated with Diagnostic Trouble Code (DTC) P0016 – 2011-2014 Ford F-150
Publication Date: March 30, 2015
FORD: 2011-2014 F-150
This article supersedes TSB 14-0194 to update the Parts List.
ISSUE:
Some 2011-2014 F-150 vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 10/10/2014 may exhibit a malfunction indicator lamp (MIL) illuminated with diagnostic trouble code (DTC) P0016. Other DTCs and driveability concerns may also be present. This concern may be due to a worn primary timing chain.
ACTION:
SERVICE PROCEDURE
1.Is the vehicle build date on or before 10/10/2014?
b.No – this procedure does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis.
2.Using Integrated Diagnostic System (IDS), with key on and engine running (KOER), select the VCT_INT_ACT1 Parameter Identification Data (PID) in the Datalogger.
a.If VCT_INT_ACT1 PID reads +6 degrees or greater, proceed to Step 3.
b.If VCT_INT_ACT1 PID reads +5 degrees or less – this procedure does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnostics.
3.Replace the primary timing chain. Refer to Workshop Manual (WSM), Section 303-01.
AT4Z-6268-C Primary Timing Chain
AA5Z-9439-A Intake Gasket
BL3Z-6584-A Cam Cover Gasket – Left Hand
BR3Z-6584-B Cam Cover Gasket – Right Hand (2011–2012)
DL3Z-6584-B Cam Cover Gasket – Right Hand (2013–2014)
BL3Z-9E583-B High Pressure Pump O-ring
BR3Z-8507-C Pump Gasket
BR3Z-8527-A Pump O-ring
7T4Z-8590-A Coolant Inlet Seal
XW4Z-6700-AA Crank Seal
BR3Z-6020-A Front Cover Radial Seal
F5RZ-6A340-B Damper Bolt
TA-357 Motorcraft® High Performance Engine RTV Silicone
ZC-30-A Motorcraft® Silicone Gasket Remover
ZC-31-B Motorcraft® Metal Surface Prep
VC-3-B Motorcraft® Orange Antifreeze/Coolant Concentrated
XO-5W30-QSP Motorcraft® SAE 5W-30 Premium Synthetic Blend Motor Oil
TA-25-B Motorcraft® Threadlock and Sealer
TA-24-B Motorcraft® Thread Sealant with PTFE
150044A 2011-2014 F-150 3.5L GTDI: Diagnose And Replace The Primary Timing Chain (Do Not Use With Any Other Labor Operations) 8.9 Hrs.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage.
DEALER CODING
6268 33
Service Bulletin No.: 14R01
Component(s): EQUIPMENT NHTSA ID Number: 10057898
Potential Number of Units Affected: 183,425
Vehicles: FORD POLICE INTERCEPTOR SEDAN 2013-2014; FORD TAURUS 2010-2014
SUMMARY:
Ford Motor Company (Ford) is recalling certain model year 2010-2014 Taurus vehicles manufactured November 24, 2008, through February 28, 2014, originally sold in, or currently registered in, Connecticut, Delaware, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, Wisconsin and the District of Columbia. When used in areas that use road salt, the license plate lamp assembly may experience an electro-chemical reaction and corrosion as a result of water intrusion.
CONSEQUENCE:
This corrosion may result in a short circuit, increasing the risk of a fire.
REMEDY:
Ford will notify owners, and dealers will replace the license plate lamp assemblies, free of charge. The recall began on July 26, 2014. Owners may contact Ford customer service at 1-800-392-3673. Ford's number for this recall is 14S08. Note: Under program 14R01, Ford will notify owners in non-corrosion states, and, at the customer's request, dealers will replace the license plate lamp assembly.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
TSB 15-0131 (2011-2015 F150)
ISSUE
Some 2011-2015 F-150 vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 5/29/2015 may exhibit a clicking/tapping or rattle type noise from the top front cover area of the engine upon initial start-up that may last for 2-5 seconds after a cold soak of six or more hours.
Full:
http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg98709.html#msg98709
Do these TSBs have to be performed while under original warranty? I have noticed that a couple of these apply to me. I purchased an Extended Warranty from my bank. Looks like I have the 12-2-8 (intermediate drifting/pulling) and 10-15-2 (rear 3rd brake light dropped out of nowhere while running errands yesterday). And to my understanding, these are supposed to be replace free of charge?
Whether you have Ford or non-Ford warranty you have to check what your warranty covers.    TSB is independent of warranty coverage, it is simply a service bulletin advising techs what to do in the event of that particular issue occurring.  Sometimes Ford does extend warranty on parts/repairs in a Customer Satisfaction Program, like brake booster, APIM, etc.  But this is rare.
Ahhhh I see. So the TSB is more of a how to/guide on some symptoms and fixes. I was more under the impression that it was kind of like a recall.
TSB 14-0105 3.5L GTDI DIAGNOSTIC TROUBLE CODE (DTC) P0087 – BUILT ON OR BEFORE 6/1/2014
FORD: 2012-2014 Flex, Taurus; 2013-2014 Explorer
LINCOLN: 2012-2014 MKT
ISSUE:
Some 2013-2014 Explorer, 2012–2014 Taurus, MKT and Flex vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 6/1/2014 may exhibit a rough idle and/or DTC P0087 after a hot engine restart.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS or Ford J2534 release 90.03 and higher. Calibration files may also be obtained at www.motorcraft.com.
NOTE: ADVISE THE CUSTOMER THAT THIS VEHICLE IS EQUIPPED WITH AN ADAPTIVE TRANSMISSION SHIFT STRATEGY WHICH ALLOWS THE VEHICLE’S COMPUTER TO LEARN THE TRANSMISSION’S UNIQUE PARAMETERS AND IMPROVE SHIFT QUALITY. WHEN THE ADAPTIVE STRATEGY IS RESET, THE COMPUTER WILL BEGIN A RE-LEARNING PROCESS. THIS RE-LEARNING PROCESS MAY RESULT IN FIRMER THAN NORMAL UPSHIFTS AND DOWNSHIFTS FOR SEVERAL DAYS.
140105A 2013-2014 Explorer, 2012-2014 Taurus, MKT, Flex 3.5L GTDI: Retrieve DTCs, Reprogram The PCM Includes Time To Clear Codes (Do Not Use With Any Other Labor Operations) 0.3 Hr.
WARRANTY STATUS
DEALER CODING
RECALEM 04
2007-2016 Edge/MKX/Flex/MKT/MKZ/MKS/Taurus/Taurus Police/Explorer/Explorer Police – AWD – Ticking/Knocking Noise From Driveline – Built On Or Before 30-Jun-2016
Some 2007-2016 Edge/MKX/Flex/MKT/MKZ/MKS/Taurus/Taurus Police/Explorer/Explorer Police equipped with All Wheel Drive (AWD) and built on or before 30-Jun-2016 may exhibit a ticking and/or knocking noise coming from the driveline area.
To identify this noise, refer to Workshop Manual (WSM), Section 100-04, and follow the symptom chart.
If the source of the noise is identified as the PTU and/or internal to the PTU, disassemble PTU assembly.
Refer to updated WSM, Section 308-07. If the PTU is determined to be repairable, utilize kit GB5Z-7P258-A and the included instruction sheet.
TSB 10-2-6 AFTERMARKET POWERTRAIN CONTROL MODULE CALIBRATION, NON-FACTORY MODIFICATION OR AFTERMARKET COMPONENTS
FORD:
2010 Taurus, Flex
LINCOLN:
2010 MKS, MKT
ISSUE
Some 2010 Taurus, Flex, MKS and MKT vehicles equipped with an EcoBoost engine may have unauthorized aftermarket modifications to the powertrain hardware and/or calibration which may result in exceeding component design limits. Such modifications could cause damage to the powertrain and/or void the factory powertrain warranty.
ACTION
Review Service Procedure
SERVICE PROCEDURE
Unauthorized calibration modifications may or may not be detectable using standard tools (Integrated Diagnostic System (IDS), Portable Diagnostic Software (PDS), NGS+ VCM). Changes can be made to the calibration and flashed to the PCM through the OBD port. Physical modifications to the hardware may or may not be present. If aftermarket power/torque-increasing modifications are suspected, care should be taken to record and store the following items: Permanent Diagnostic Trouble Codes (DTCs), Pending DTCs, Freeze Frame Data, Mode 6 and Mode 9 data. The data should be printed and attached to the repair order for later reference.
The DTCs, freeze frame data, Mode 6 and 9 data can be obtained by using the IDS, PDS or NGS+VCM under tool box selection. The Powertrain tab will provide the OBD Test Modes tab and Mode 6 and 9 data selection after the vehicle has been identified.
Attempting to increase the engine output via recalibrating the PCM may result in poor drivability, DTCs, or component failures. A partial list of calibration induced component failures is given below:
^ Piston damage.
^ Spark over-advanced (knock-induced damage).
^ Insufficient enrichment.
Excessive Cylinder Pressure:
^ Turbocharger damage.
Over-Speed:
^ Catalyst damage.
Over-Temperature/Melting:
^ Transmission, PTU, Torque converter damage.
Hardware Modifications:
The following list contains items that are frequently modified in an effort to increase the engines torque/power output. Modifying these items may, or may not improve the performance, but can lead to drivability issues, DTCs and possibly component failures:
^ Air induction system (air box, low pressure and high pressure air ducts).
The system may be particularly susceptible to flexible air ducts between the air filter and the compressors. Restrictions on either side of the compressor can result in over-speeding the turbo (Figures 5-6).
^ Wastegate actuator pre-tension.
The full load output of some turbocharged engines will increase if the wastegate spring pre-tension is increased. This is not the case with the EcoBoost engine. Adjusting the wastegate pre-tension out of the specified range can result in DTCs. A tamper evident paint dot has been applied to the wastegate actuator adjustment mechanism to make modifications more apparent.
^ Throttle inlet and intake manifold pressure sensors.
These sensors and the associated wiring should be inspected to verify they have not been modified.
^ Additional fuel injection devices.
The high pressure fuel system used for the EcoBoost engine will not support additional fuel flow beyond what the factory calibration requests. Inspect the engine for an additional aftermarket injector(s) located somewhere in the induction system to provided increased fuel flow.
^ PCV system modifications.
If the PCV system is modified (vented to atmosphere being the most common modification) it can result in a condition where oil gets past the turbine seal even on an undamaged, fully functional turbocharger. Oil in the exhaust system may not be sufficient evidence to identify a failed turbo if the PCV system has been compromised.
^ Compressor bypass modifications (a.k.a. blow-off valve, or anti-surge valve).
It is common to modify these components so they make more noise. If the aftermarket devices fail to seal properly when closed, elevated turbo speeds and compressor outlet temperatures will occur.
^ Exhaust air path/system.
Removal of catalysts or mufflers/resonators to reduce exhaust backpressure may result in over-speeding the turbo(s).
February 27, 2017 MANUFACTURER COMMUNICATION NUMBER: SSM 46412 - PTU
Components: POWER TRAIN, EQUIPMENT
NHTSA ID Number: 10095858
Manufacturer Communication Number: SSM 46412
Summary
SOME 2007-2016 EDGE/MKX/FLEX/MKT/MKZ/MKS/TAURUS/TAURUS POLICE/EXPLORER/EXPLORER POLICE EQUIPPED WITH ALL WHEEL DRIVE (AWD) AND BUILT ON OR BEFORE 30-JUN-2016 MAY EXHIBIT A TICKING AND/OR KNOCKING NOISE COMING FROM THE DRIVELINE AREA. TO IDENTIFY THIS NOISE, REFER TO WORKSHOP MANUAL (WSM), SECTION 100-04, AND FOLLOW THE SYMPTOM CHART. IF THE SOURCE OF THE NOISE IS IDENTIFIED AS THE PTU AND/OR INTERNAL TO THE PTU, DISASSEMBLE PTU ASSEMBLY. REFER TO UPDATED WSM, SECTION 308-07. IF THE PTU IS DETERMINED TO BE REPAIRABLE, UTILIZE KIT GB5Z-7P258-A (PTU Idler Gear Repair Kit, about $315) AND THE INCLUDED INSTRUCTION SHEET. FOR CLAIMING, USE CAUSAL PART 7P258 AND APPLICABLE LABOR OPERATIONS IN SECTION 07 OF THE SERVICE LABOR TIME STANDARDS (SLTS) MANUAL.
77 Associated Products
Vehicles
MAKE MODEL YEAR
FORD EDGE 2007-2016
FORD EXPLORER 2007-2016
FORD FLEX 2009-2016
FORD TAURUS 2007-2016
FORD TAURUS POLICE INTERCEPTOR 2013-2015
LINCOLN MKS 2009-2016
LINCOLN MKT 2009-2016
LINCOLN MKX 2007-2016
LINCOLN MKZ 2007-2016
SSM 44856 - Various 2011-2015 Vehicles - Cruise Control Speed Setting Display May Not MatchSpeedometer
Some 2013-2015 Fusion, Taurus, 2011-2015 Explorer, 2013-2014 Edge, Flex, 2013-2015 Lincoln MKS, MKX and 2013-2014 Lincoln MKT, vehicles may exhibit a cruise control speed that does not match the speedometer speed. The Instrument Panel Cluster (IPC) provides a tolerance which allows the speedometer gauge to display between 3% lower and 7% higher than the actual vehicle speed. This means that with an actual vehicle speed of 96 kmh (60 mph), the speedometer may indicate between93 kmh (58 mph) and 103 kmh (64 mph), which is normal. Refer to Workshop Manual(WSM), Section 413-01 Description and Operation, Instrument Panel Cluster (IPC). If you are outside of this tolerance range, refer to the WSM for normal diagnosis.
SSM 47119 – 2011-2018 Explorer/Police Interceptor Utility/Police Interceptor Sedan Taurus/Flex/MKT and 2011-2016 MKS – 3.5L EcoBoost – Engine Assembly Replacement
During 3.5L EcoBoost engine assembly replacement, inspect the color of the positive crank ventilation (PCV) camshaft cover adaptor located next to the high pressure fuel pump on the original engine and compare to the service replacement engine.
The adaptor color of the service replacement engine must match the original engine.
If the adaptor on the original engine is green, install a green adaptor (HL2E-6762-AA) on the service replacement engine.
If the adapter is removed from the camshaft cover, damage will occur to the adapter locking mechanism.
Make sure detached pieces of the locking mechanism do not fall into the open port during removal.
APPLICABLE VEHICLES
2013 – 2018 EXPLORER
2011 – 2018 FLEX
2011 – 2016 LINCOLN MKS
2011 – 2018 MKT
2011 – 2018 TAURUS
