RedCandySHO
I figured I would share this info as I couldn't find it here prior. I needed both a constant 12v and a switched 12v source in the interior for an accessory.
I located both on the interior fuse panel under the steering wheel area.
Switched / Key On Only 12v
Fuse #38 - Auto Dimming Mirror etc.
I used a Mini ATM Dual Add a Circuit - This retains the factory fuse and has a fuse for the accessory connection.
Constant 12v - Alway On
Fuse #47 - Spare (not used for anything)
Also used a Mini ATM Dual Add a Circuit - This retains the factory fuse and has a fuse for the accessory connection.
Hope this helps anyone else trying to find a 12v source in the interior for a radar detector, dash cam etc.
