okedokey...
Whats bugging topher is this :
#1) I can see the boost is steady from the MAP .. BUT the Throttle-Actual in many cases is fluttering as compared to the throttle position, and along with the Throttle-Actual is Wastegate %% .. so your foot goes down slow and steady, but the throttle blade, wategate are blipping up and down. In some cases its more then 7% but less than 10% .. in other sections it is fluttering 10-17% and you would feel that as a surge. Most of this fluttering is around 30-50% throttle. under WoT i do not see the same behavior. BUT then we get to #2 ..
#2) I do not log the Slippage of the TQ converter. Never needed to. so When i look at yours i cannot say ''oh there it is...'' BUT i find it damn coincidental that your TQ-slip logs look jittery as hell ''around'' the same time the flutter seems creep up.
so for me IMO my next step would be this :
#1) find someone who has a data log of normal driving + WoT who is logging TQ-slip and compare ..
#2) crawl under truck, check the ??speed sensor?? (Z/SHODD confirm speed sensor location) PHYSICALLY, check terminal, loose etc..
My thought goes to a previous ''surging'' case where a bad speed sensor cause the upstream ECU to rapidly adjust throttle and by proxy boost waste % beacuse the ECU has zero clue WTF is going on past the input signal.
other possibility .. bad TQ-converter .. in this case i am thinking of ''chatter'' versus outright slipping
