EcoBrick Bob
They Darreli, First SHO BPD & others are spraying 100% methanol thru a #10 nozzle ( calculated at 10 gal per hr at 100 psi). My guess is their pumps are putting out 200+ psi. Nozzle is located just in front of the throttle body. Not sure what octane gas they(Darelli & First SHO are using at Milan. Definitely 93 and perhaps 100 octane unleaded. Darreli's FRP at over 1500 is very good. I have seen much lower FRP's when I was running 50-60% methanol spray with stock turbos. My lambda #s were between .80 & .82 which is around 11.6 to 12.0 A/F. When I added a Kenne Bell Boost a Pump which up's the voltage to the stock LPFP (Low Pressure in tank fuel pump), my FRP increased by approximately 200 psi
