FORScan?
Gjkrisa
Member
Here is info on how to make vehicle changes using forscan.
Mobile application is ONLY a data logger must use a computer to make changes.
Download link http://forscan.org/download.html
https://youtu.be/0I2KEEMPSt8
Info about getting license to make changes.
without license it's just diagnostic logging software.
http://forscan.org/forum/viewtopic.php?f=5&t=836
Code edits not in forscan yet.
Remove double honk
bdycm
726-16-01 0211 57 as built
726-16-01 0201 47
AWD distribution driver gauge
ipc
720-01-02 8AFC-4CF0-3F2B asbuilt
720-01-02 BAFC-4CF0-3F5B
Enable Engine Hour Display
720-01-02 88FC 40F0 3D1B to
720-01-02 88FC 40F3 3D1B
Nav on IPC:
Before (compass on IPC)
720-01-02 BAFC 40F3 3F52
After (nav on IPC)
720-01-02 BAF8 40F3 3F4E
Turn off amp and have clean preout from radio from fusion forum
http://www.2gfusions.net/showthread.php?tid=3704
Ford fusion write up for FORScan
http://www.2gfusions.net/showthread.php?tid=4573
Change factory splash screen.
http://www.fiestastforum.com/forum/showthread.php?t=11920 page 5
https://drive.google.com/folderview?id=0BySleg7SM4KcSzVYeF9ueGlKWVE
http://forscan.org/forum/viewtopic.php?f=5&t=2331
http://www.f150forum.com/f118/forscan-software-enable-disable-features-your-truck-348987/index540/
Online updated spreadsheet of what you can change from f150 forum.
https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/htmlview#gid=815852466
Mustang spreadsheet
https://docs.google.com/spreadsheets/d/1-gytuV9qPfxvLLcFBIl6nt9h5MGW-NWEPc04cN-ro60/htmlview#gid=0
Taurus spreadsheet-currently down trying to find something similar
https://onedrive.live.com/view.aspx?resid=6DF661C7B798C246!36209&ithint=file%2cxlsx&app=Excel&authkey=!AOW_-cRixqVIJWM
Good forscan forum for the Taurus
https://forscan.org/forum/viewtopic.php?f=5&t=2662&hilit=2015+ford+taurus+awd
Flex spreadsheet
https://docs.google.com/spreadsheets/d/1qe8PznI_XvEb5NPaRCN5OBXpcdrIvx6qvenWbHRtRA8/edit?usp=sharing
Flex forum
https://www.fordflex.net/forums/viewtopic.php?f=3&t=17209
Explorer forum
http://www.explorerforum.com/forums/index.php?threads/new-forscan-update-allows-module-programming.442848/
Explorer spreed sheet
Sync2 https://docs.google.com/spreadsheets/d/1JHLK2oCBe-E5om9VNeY6e3NwboO9Em0dDBZIgUVyGxc/htmlview#gid=0
Sync3
https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2016-2018_Explorers
I recommend
http://www.obdlink.com/mxwf/
Or
http://www.obdlink.com/mxbt/
Go WiFi if you have iPhone
Others say kiwis are a good cheap option I've used the first kiwi it was fine but know it couldn't do hi and low can speed.
https://www.plxdevices.com/category-s/195.htm
Kiwi3 it's has poor reviews on the play store.
Here is some information about reading hex for odometer.
https://youtu.be/XKXn_EcZblY
SHOdded said:
AFAIK, still requires a Windows OS to access full capabilities.
You are correct. They have an Android and iOS  version but both don't have as much capabilities as the Windows version.
Anyone willing to give me there vin if they have a loaded 16/15 Taurus sho w/o pp?
Just found this program to compare as built data and one day I wanna try adding adaptive cruise control and maybe some other stuff
http://www.compulsivecode.com/Project_AsBuiltCompare.aspx
http://forscan.org/forum/viewtopic.php?f=5&t=2012&start=10
I'll try to make a video tomorrow showing how slow so you can get an idea maybe someone with the wifi version can make one?
If all you need is a VIN, I'd search the sale listings: dealers, private listings, even ford.com.
I'd give you mine, but I have a PP (no ACC).  You're still going to need the ACC components (radar, etc.).
Question for you FORScan gurus.
Can you get into BCM parameters and see any TPMS info?
Also, what bluetooth adapter are you guys using? If I pull the trigger, I want to make sure I get something compatible.
Thanks!!
You can see tpms info what exactly are you looking for tomorrow morning I'll take a look at it.
By far the best odb device is the obdlink MX I like Bluetooth version because it's easy to connect and still have internet on my phone but the wifi  has quicker data refresh.
https://www.amazon.com/gp/aw/s/ref=is_s_ss_i_0_8?k=obdlink+mx&sprefix=obdlink+
This looks very neat..
https://www.amazon.com/gp/product/B006NZTZLQ/ref=s9_psimh_gw_p263_d3_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0FDJ7ETZ3DC8DSKYGSP2&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846&tag=scantonet-20
Awesome! Ordered the MX, thanks!
I'm not really sure what I'm looking for. LOL
Do you have the ability to see your sensor IDs and/or add/change/remove the IDs that are present?
I'm thinking step 1 is to read/clear any stored BCM codes to see if that allows me to train new sensors, but if I had to, I was wondering if I could manually add the codes I read from the TPMS service tool into the BCM.
Codes or PIDs, Mike?  You cannot add PIDs into any module.  You can add PIDs to Torque Pro to read the existing PIDs in the vehicle's modules.  You cannot add PIDs to Forscan, period.  forscan.org forums are a good resource to browse through/ask questions in as well.
Thanks, Manu.
I don't think I need to add any PIDs. I was curious if it was possible to manually add the 8 digit alphanumeric TPMS ID to an existing cell on the BCM. Like if there was old sensor data stored, could I replace it with new sensor data?
And/or if there was a stored DTC on the BCM, would I be able to clear them with FORScan?
I'll try over on the Forscan forum you mentioned as well. Can never have too many hooks in the water! :)
Thanks for the feedback!
I see, you want to populate the data values into the PIDs and force recognition that way.  Great idea, IDK if it is possible though, hope it is.  Then we would find out whether the system periodically scans these values and resets to the most current discovery or simply leaves them alone :)
Correct! That was my thought. Force it in and see if it's accepted. Sheesh, when it's put that way, I feel ashamed. LOL
I just posted on the FORScan forum as well. Here's the link for anyone who wants to follow along. I'll be sure to post a resolution here as well, if/when I get this figured out.
http://forscan.org/forum/viewtopic.php?f=5&t=2943
Use forscan to  change to different factory splash screens
