StealBlueSho said:
Those are much better runs but I think the reason the rail pressure doesn't drop out its ass it because the load/timing/boost is not as high. Curious though, I did see the throttle closing up in fourth at 14.5 seconds in the first run and second run. The third run has it closing up in third.
I have seen similar stuff in mine. I was seeing fuel pressure down to 1100 PSI in third gear under a load of 2.03 and boost of 20psi+ and having the ecu close down the throttle. But that only happens when I go WOT from a roll around 45mph-50mph. My 0mph-80mpg or so doesn't have the problem but I am seeing loads around 1.8 and not 2.03+. Every tune revision I have received the load is being dropped slightly.
However, after countless hours researching what other people are doing, it APPEARS that our HPFP just have a hard time keeping pressure when the load exceeds 1.8 and supplementing with WM seems to assist. And there is a variance to how well the HPFP keeps pressure per car and that is also a known issue.
SO I would think from a SCT standpoint there is going to be varying tunes to accommodate the tolerances in our cars which is expected. That is the reason I went with Torrie. I would be VERY curious as everyone else is as to what LMS datalogs look like to see if they exhibit a similar behavior. Since they send the same tune to everyone I would image the ECU does some correcting on some of the cars out there.
I will caveat this by saying I am not expert in these things, just attempting to put 1+1 together lol
I am very curious as to what Torrie says, please keep us updated?
Did you ever reset the KAM on yours? SCT X4 apparently does not do that when re-flashing a new tune from what I am reading... I could be wronng
There is a setting in options on the handheld to clear your KAM.
Here are some of my logs...5,6,7 and 8,9,10 are different revisions 8-10 being my current.
5 is weird because I left TC on.
On your stop log I noticed your pressure tanks about 4K rpm in 1st, that is something I've never seen before and my drops are always after upshifts.
