AJP turbo said:Do you believe that the fuel stations are lying about the octane rating on the pump when winter fuel is in use?...I don't
polskifacet said:AJP turbo said:Do you believe that the fuel stations are lying about the octane rating on the pump when winter fuel is in use?...I don't
I do believe that in Chicago a lot more sh*t gets through just because of sheer volume, the station I use is the best I can get, it was recently built so it has new tanks, I have tried others and get worse LOR and the same result. I also believe that the tune can be massaged to account for this. I don't know what to do, without pro logging, I don't like throwing "my sh*t don't work, fix it" at LMS. Would be neat if there was a obd logger they could send out with an sdcard and have actual data to look at.
Not to mention sometimes drivers mix up the grades when filling the underground tanks.Livernois Motorsports said:AJP turbo said:Do you believe that the fuel stations are lying about the octane rating on the pump when winter fuel is in use?...I don't
Not saying the fuel stations are lying or selling garbage fuel occasionally on purpose , no. But some stations have water / condensation in their fuel occasionally which can cause a lot of trouble even in bone stock vehicles. This is why I keep a bottle of Heet water remover / fuel line antifreeze in my Car, truck , and snowmobiles all winter long. They wouldn't sell the stuff if fuel stations never had moisture of some sort water in their fuel on occasions. Not sure if you have ever had a fuel line freeze or water in your fuel, but it happens here in Michigan, especially in rural parts up north when traveling or snowmobiling more often than some would think. Most all avid winter motorsports / powersports enthusiasts would agree, keeping water remover / gas line antifreeze or something equivalent handy is pretty much standard. So using a busy station usually means their fuel has had less time to sit in the ground and collect moisture.
Brenton "keep it real"my friend. Z14SHOCAR said:*cough* It's not the fuel *cough*
I do appreciate LMS and how they are attentive to the forums. Like I said, they have GREAT customer service.
Great idea!FoMoCoSHO said:You can run 2 bottles of HEET and since it's straight meth its also an octane booster. If it isn't fuel quality related
it could actually add to your woe as meth has a very low stoich point (6ish) and will add to a fuel demand issue.
polskifacet said:I don't mind the issue so much as making sure my sh*t doesn't blow up again. LMS doesn't sound too concerned in the emails, they haven't said that the hesitation is a concern for damage. Also seems like they know the root cause but it requires a lot of massaging to make my car happy.
polskifacet said:Quick update. Got new tunes from LMS. Problem seemed to be fixed but then the temp dropped to 13f. Same issue had to reflash to 91 octane tune. couple wot pulls seemed ok.
Livernois Motorsports said:polskifacet said:Quick update. Got new tunes from LMS. Problem seemed to be fixed but then the temp dropped to 13f. Same issue had to reflash to 91 octane tune. couple wot pulls seemed ok.
I suggest continued contact with the tuning department in regards to this. Unfortunately we get to a point where battling weather can become a hassle. We never know if we are going to have ten 13 degree days or one day of that. Chasing weather gremlins can lead us down the rabbit hole.
derfdog15 said:Livernois Motorsports said:polskifacet said:Quick update. Got new tunes from LMS. Problem seemed to be fixed but then the temp dropped to 13f. Same issue had to reflash to 91 octane tune. couple wot pulls seemed ok.
What about the benefits of cold weather tuning though(such as finding limits of the car). If my tuner told me we were going to abandon tuning/not worry about an issue due to weather (especially cold weather - worst case fueling scenarios on the GDI Ecoboosts) I would be pretty upset and look elsewhere. If you can get the car running optimally in the cold, with regards to fuel pressures, boost, etc then you KNOW it can run just as well or better in warmer conditions. ie. there is a little margin left in my fuel at WOT currently, and with 10 degree ambients, so I KNOW my car will run, without any issue in warmer spring/summer weather when it is going down the track.
I don't want to have to mess with running a different tune for winter, or a lower octane tune due to fuel quality issues, or weather. As you said, one day it may be 50 degrees, the next its 20 degrees when I leave for work and there is snow on the ground. I don't have time to load a different tune each day, or worry about doing so.
