?Hmm? This is your Alky kit though right? This would not be comparable to SNOW-stage-1 which is not a scaling sprayer? Or do ‘’all’’ kits have a ‘pick up’ to turn on then an ‘initial spray volume’ that increases to ‘’full spray’’ settings with either a internal 'count down' or sensing load (via voltage or boost trap)?StealBlueSho said:That is how to set when the pump turns on...
There are two other adjustments that need to be made.. There is the "Initial" Rheostat sets the prelim ramp from start to finish... and then there is this... (Again... too lazy to take my own pictures.. credit this one to BPD1151)
This controller has the gain setings which dictates how fast/how much the meth ramps up while you are spraying or slope... I asked Julio if there was a best practice for this and here is his response..
StealBlueSho said:So how did I set it up you might ask? Simply put... I have configured it on LMS's tune and Brads tune... for me it takes about 20 minutes or so using my laptop to datalog through my SCT x4 so I can view real time feeds to make the adjustments... Do a couple slow accelerations while the boost building and monitor the LEDS that came with the Alky kit.. when it hits green I make a note of which KPA it kicked on at.. now I know when it kicks on...
Then I like to do a 3rd gear pull.. I monitor knock, AFR, and STFT... the STFT lets me know how much I am spraying throughout the run...and if I need to make any adjustments based on knock... If my trims are pulling a TON of fuel during the inital kick on the Meth, I adjust the initial back as long as I don't have any knock...
once I get that done, I monitor the rest of the pull for knock and adjust gain accordingly.. once I can get several runs in in where there is no KR then I am done adjusting the kit. My STFT's tell me how much fuel I am offsetting with Methanol... The idea is to just spray enough to stop the knock retard and no more... if you are spraying more than you need, then you are potentially hurting power production from running too rich..
THEORY\QUESTION .. Since I am not going to make the car dependent on meth, I would then tune for SFFT limits then (I assume?). IE in small increments find where the SFFT limits are and dial back down and call it good.
