Z is probably correct, but I do wonder about adequate function of fuel pumps... Maybe you're getting too lean for that instant.curry67 said:I have a sct x4 I datalog with. I almost always see knock from 3 to 6 at wot for a split second.
Sent from my SM-N910W8 using Tapatalk
Lol, dump some 87 in your tank on the stock tune.....curry67 said:This knock is driving me nuts I feel like this isn't gonna work. I don't feel comfortable tuning it anymore.
FoMoCoSHO said:Lol, dump some 87 in your tank on the stock tune.....curry67 said:This knock is driving me nuts I feel like this isn't gonna work. I don't feel comfortable tuning it anymore.
Your head will probably explode.
I wouldn't get too worked up, the car is very good at protecting itself.
curry67 said:I just don't think I should see any with 94 octane and 10 percent ethanol. It's top tier supposedly.
curry67 said:So would thst explain higher knock readings on higher octane?
Even on stock tune?ajpturbo said:curry67 said:So would thst explain higher knock readings on higher octane?
Maybe....But you really need to have someone verify on a log just to make sure that's really what you have. Then I would want to look for trends....5 and 6 is a little high...If it's an isolated event then no biggie. If it continues then your timing tables need work and are over advanced and you are relying on the knock sensors.
Take your device and under user options retard the spark by 4 or 6 degrees and see if it's better...If it is then your spark tables are over advanced.
I like my knock sensor readings to be like my short term fuel trims.....They should hover around 0. A little above and below is good.
X2 on that ?curry67 said:Even on stock tune?ajpturbo said:curry67 said:So would thst explain higher knock readings on higher octane?
