G
geswek
Guest
Getting it off is easy, you can do it with your hands. Grab back side closest to rear window and pull down.
I went back outside and took some photos. These are all orientated so that the left "pod" is drivers side and right "pod" is passenger side.
The assembly has 3 wires (2 signals/power and 1 ground). I don't have electrical schematic so I can't tell you what the purple wire or green/yellow do.
I used the ground wire off the plug that goes into the entire unit; with door closed I turned on map lights (driver side has no bulb at moment). I put positive on "red wire" and it read 12.63V and on "yellow wire" 0.1V. This was on both sides; with and without bulb. I turned switch off and map light went out--voltage didn't change. It was still getting 12V's.
I don't know if this has a circuit board controlling it or what--I don't know what else to honestly do except swap with with someones that does work and see if it's just a bad unit.
Sorry to hear you are sick, appreciate help. Hope you get to feeling better!
