Light replacement
jtoddk98
Member
I just tried to replace my reverse lamps with LEDs. I took it out and noticed that the bulb and socket are one piece looks ford proprietary. So should I return the bulbs I have or what?
So you have these infamous bulbs?
http://www.ebay.com/itm/PHILIPS-7010-HPC16W-PU20D-1-12184-X-2-BULBS-16W-BACK-UP-LIGHT-CHEVROLET-SATURN-/160835305649
Yeah, you are in a tight spot.  Best return the LEDs.  There is a place on the web that shows how to wire the socket for a standard base LED and make it work that way, but def not plug&play.
jtoddk98 said:
Yup those are it. Is there a led plug and play option?
vLED Tritons is about as close as it gets... They make a back-up bulb option, but it is actually a system.
That's unfortunate. I replaced the brake lights and the little red running light back there with red LEDs, nice improvement, no more white light showing through the red lens. Looks good
Got it done along with my DIY led puddle lights. Bake em at 200 in the toaster for a few minutes, and pry them open, not bad.
