The Ecoboost was initially designed as a FFV. On E-85 it was rated at 415/400. I suspect they axed the FFV part cause they knew the tuners would try to exploit this and they were uncomfortable because they knew they would run out of HPFP very quickly above those levels. All the hardware is Bosch that is rated for E-85. Rated for hardware robustness that is, not the insane amount of HP some of us want to make.ajpturbo said:bamsho said:If so I would find away to check fuel pressure on the lpfp. The E85 could of damaged it.
Low pressure pump is a non issue
Doubt the e85 damaged it....just curious why u would think that?....the fuel filler says e0-e15 because the high pressure pump really cant support more E as far as ford thinks, with their saftey net in mind.im pretty sure all the fuel system has been upgraded to handle various fuels...fomoco posted something about that a while back
I think on a stock tune you pretty much have 2000 psi at the rail at wot all the time so everyone running a 3 bar tune on pure gas would have fuel pressure below what ford preferred....
Its not a ffv car because the pump wouldnt have the output not because the components can't handle ethanol fuels
http://ophelia.sdsu.edu:8080/ford/01-24-2009/innovation/environmentally-friendly/gasoline/twinforce/fuel-efficiency-364p.html
