The popping happened since I bought the tuner/plugs/t-stat. The 91 tune didn't fix the issue and a factory tune doesn't show a problem.
As per temperatures, my car is indoors and is 50+ degrees most of winter.
The issue only happens under WOT. If I am slightly off WOT, I don't get popping and the car runs great.
The popping happened well before my e85 experiments. I only ran it for about a week, and never mixed more than 1-2 gallons per 16 gallons of gas; yes, if I wasn't empty, I lowered the amount of e85 to keep a .125 blend. I did, however, see better gas efficiency (3-4 MPG) when I added it in, until what I assume, the fuel trims adjusted, where I got worse.
My next step is to replace the plugs with another shop that will gap the plugs correctly. The plugs I received from Livernois were not all .030 -- some were in the .0315 range. Shipping doesn't expand the gap....
Do any unleashed customers have ANY issues with ever with popping? I may just ditch livernois and move to unleashed -- At least Torrie is willing to work with his customers on datalogging and getting to the root of issues... instead of telling them to "change the plugs they provided", "change the tune", "change the intake"...
I'm following through with their suggestions, but seriously... this is getting really old. OVER one year's worth of issues.
