WickedSHO said:After seeing all these numbers you guys are posting for your 0-60. My 5.4 seems extemely slow.....I'll need to do some runs on a good surface and see if I can get it any better. If not, sounds like I have a problem.
The 5.4 (or a tick quicker) is about what it should run when stock. Either the timing method you are using is incorrect or something else is going on. I know the K & N will raise the IAT but would it make a full second of difference? Not sure about that.....
If I do not brake torque at launch, I am about 1/2 second slower - around 4.5. Leaving around 1700 is literally slingshot like - especially on a high traction surface.
