StealBlueSho said:
Yes very true, but you need to tune specifically for the meth since it alters A/F? You also have to sure it is always full as if you run out things can go boom. I think with the cooling setup above it would be a install and forget about it deal, no specific tuning needed. You can run or not run based on temps and what you have going on and not have to worry about it. If it is a cool morning/winter day, don't turn it on, warm summer day and you want to play, turn it on (or better yet have the system on a temp switch so it could turn on/off on it's own..)
I see it sort of like old school pushrod cars. Real easy to just throw a nitrous plate under the carb. More expensive and time consuming is to throw intake/cam maybe heads at it. They can net the same end result, but one is there all the time, the other you have to keep full and buy consumable based on how much you use it.
