Massive fuel leak into engine and out exhaust
So I talked to the service writer earlier and things are not going well. They said the injector(cylinder 1) is fixed under the warranty  but  cylinders 1 and 3 are down. She was unable to explain more but said the cylinder was are NOT scorned and that they are waiting on an e-mail from Ford and what to do next per prototypical.
  She did mention "tune" to my dislike......she said she was not sure if the warranty would cover whats next or not. I believe the dealership that had my car for 9 days and somehow went through 3/4 of a tank of gas only to decide they didn't know what was wrong may have something to do with the current issue.
Not happy
It doesn't make sense that the tune did anything to the car.  More likely that the real culprit has not yet been found.  Rare to have an injector fail this early, let alone multiple injectors.  Faulty injector controls, maybe.  I think you will at least get an honest evaluation from Ford Engineering.  As far as the other dealer, not sure what they did or how much liability they face, as they are not a Ford dealership.
Hang in there.
This is sounding a little scary.  I hope they can get it straightened out at no cost to you.
If the injector for cylinder #1 is fixed.  The dealer stating that cylinders #1 & #3 are down, would mean in my opinion that those cylinders are down on compression.  If so, how much is the big deal..  Again, this is just my opinion, but I bet you have some piston damage, like I did... "ringland fractures" which allow the cylinder to leak down quickly when not running but when turned over to test compression. Mine was caused by me spraying denatured alcohol ( ran out of methanol) and lugging the engine which resulted in too much fuel/liquid in the cylinders and caused chunks of 2 pistons to break away and cracks in the ringland area of a 3rd. And if I'm right ( I truly hope I'm not) they will be tearing your engine apart next.  Since you have a tune, and the dealer has sent Ford all the data, which includes all of the things they request in that TSB I mentioned elsewhere, Ford won't warranty anything that is even remotely tune related.  If the non-Ford dealer burned thru that much fuel testing their theories, they may have caused the problem, or it may have been caused by the injector flooding the #1 cylinder. You can blame much of this on the #1 cyl. injector, but not sure how the #3 cylinder can be explained.
Also, I wasn't truthful at first, and believe that not admitting things makes the dealer less likely to be helpful. (The service writer directly accused me of tuning my car and I denied it.) My vehicle was completely stock when it went in, except for badges and the rear Magnaflows.  Ford got pix of all of those mods plus my painted calipers, custom wheels etc.  Ford told the dealer that the sent data proved my ECM had been flashed over 100 times ( close...) and that the last time was only 12 key turns ago... and vehicle had 35K...  You may explain away a couple flashings to a dead battery... but not the number I had. If it's a major repair, that's about your only hope, and proof of the accident/towed vehicle that wouldn't run.
Good Luck!
