Initially she fired up and idled without much to talk about, but then it started to smoke pretty bad, but then it cleared up nearly 100%, but not quite.
I hear a hissing, something like an air/vacuum leak around
PCV/AOS EVAP purge the PCV valve inlet on the AOS attached to the rear valve cover on the passenger side. The leak seems to be coming from the quick disconnect on the
AOS EVAP purge PCV valve side coming from the intake manifold. (I had to find this by shoving a vacuum hose in my ear and probing around.)
I've also got a fault of P2198 (O2 Stuck Rich B2S1) and a pending fault of P2196 of O2 stuck rich B1S1. Sounds like she had more than one problem before all this started. Going to see if I can overcome this
AOS EVAP purge PCV valve leak first, but not sure if it's enough of a leak to get things stuck rich. If it helps, I heard this hissing on the side of the road when the initial problem occurred, I just didn't have anything with me to MacGyver up a stethoscope on the side of the highway.
I've got some videos that are uploading now and I'll make a follow up post when they do. I also wonder if I've also got some bad gas that may have assisted in the demise of an already ill injector. I'll probably find the best way to pump all this out and set fire to it while celebrating my independence today. (In a safe, controlled manner, of course.)
I will say the problem is MUCH better as the car idles and revs smooth, but it's not 100% yet.
EDIT: Also, the super rich fuel smell is gone. Before the smell of raw fuel was so bad you'd cough/choke on it. Now it just smells a little rich.
EDIT2: I incorrectly identified a part as some sort of AOS, but I it appers it's really part of the EVAP system as I discovered here. I'm hoping this could be part of my rich codes. I've updated my original post accordingly.
EDIT3: Seems like it really is a PCV valve and AOS combo. At least according to #9 and #10 on
TASCA's page. I'm going to replace the valve and the hose going to it, which can be found on the same page above, it's #11.
Videos forthcoming.
