Finally pulled the trunk apart to see what was in there. Its a 10" sub, dual 2 ohm voice coil free air. The cover makes a bit of an enclosure but is by no means sealed, in fact it has a bunch of holes in it. I measured the opening and it is exactly 10 inches so it should fit just about any 10 inch sub as most are under 10 inches for the hole. The stock sub is dropped in from the top which means I have to figure out how to pull the rear deck apart, that sucks. Once I get that apart I will likely mount the new sub from the bottom so I don't have to deal with that again. Here are some pictures.
