Are you looking for the Fuel Rail Pressure Sensor? It is located underneath the Intake Manifold
Removal and Installation
WARNING: Do not smoke, carry lighted tobacco or have an open flame of any type when working on or near any fuel-related component. Highly flammable mixtures are always present and may be ignited. Failure to follow these instructions may result in serious personal injury.
WARNING: Before working on or disconnecting any of the fuel tubes or fuel system components, relieve the fuel system pressure to prevent accidental spraying of fuel. Fuel in the fuel system remains under high pressure, even when the engine is not running. Failure to follow this instruction may result in serious personal injury.
Release the fuel system pressure. For additional information, refer to Section 310-00 .
Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
Remove the intake manifold. For additional information, refer to Section 303-01B .
Disconnect the Fuel Rail Pressure (FRP) sensor electrical connector.
Remove the FRP sensor.
* To install, tighten to 33 Nm (24 lb-ft).
To install, reverse the removal procedure.
