New Member - Say Hello to EcoHell
EcoHell said:
TopherSho said:
... MAP sensor ... was the map sensor ELECTRICLY bad and grounding out?  WTf ... there has to be more than ''opps bad map''
You can say WTF and has to be more to it, but if there is a TSB describing what exactly occurred on EcoHell, this has to be happening with others.  I never go online reading TSBs on my vehicles, but will definitely look for them when something goes wrong on my vehicles from this point forward.
There is a little more to my story, but again to have a TSB on this very issue, I cannot say that "the little more to my story" was the real reason/cause.  It may have pushed my vehicle to have this happen quicker given the age and miles on EcoHell, when others have been going through this issue.. again to have an actual TSB on it...things that make you go hmmmm..
So my 'little more to the story" is this.. at 700 miles I began modding EcoHell and purchased the Power Stage 2+ Package (no longer being offered) from LMS.  This included the tune, go fast part and changing the 2 bar MAP sensor with their 3 bar MAP sensor.
For some reason after the install of their package, I had to return to Ford (I cannot remember why), but it never happened.  We believe one of the mechanics may have swapped the 3 bar MAP sensor back to the 2 bar MAP sensor in preparation to bring her back to stock.  We say this because the part numbers on the other 2 bar MAP Sensor is the same on the one that was supposed to be a 3 bar MAP sensor.
Being I do not beat on EcoHell, the 2 bar MAP sensor was ok...that is ok until this year.  So with the voltage issue causing my headache in Florida with the "wrench" light could have been co-contributed with this sensor, as well as the PC playing havoc.
Look at it this way...better to have a $85 sensor than the transmission or a module going bad.
Plot thickens.  You can convert a 2 bar into a 2.5 bar.  Hence the map serial would be the same.  If you replace a ''3bar'' sensor on a  tune ''expecting'' 2.5-bar range or 3-bar range voltages to a 2bar it wont even idle correctly.  and will throw a wrench when you rev it above 2000 rpm..  so i do not think the ford tech replaced it.  it would have thrown codes instantly on the next startup if the tune was looking for a 3-ba5 or 2.5-bar.
In the VERY EARLY days of tuning SHO's modded sensors were fairly common to get from UNLEASHED and LMS.  It should be super mega uncommon to get one now.  I could not find it but there is a topic on it here on the forum .. it dealt with pre-install inspection and the user saw the sensor sent to him by Torrie has the same serial as a 2-bar..
I know of a post similar or the same one you mention regarding the part numbers being the same.. I was confused reading that post.  Curious... so even from a start up, idle being idle regardless of tune, From what I understand about MAP sensors, the 2 bar MAP sensor can handle up to 14.7psi, on top of the sea level pressure of 14.7psi, so totaling 29.4psi.  Not sure what my tune is pushing but without beating on it, but perhaps I was not pushing over 29psi.
So with what you are saying, I would have received codes with a 2 bar installed as opposed to the required 3.bar with my tune.  Interesting.
ridered74 said:
  If you had the wrong map sensor it wouldn't even idle correctly, as soon as you start it with wrong map sensor you will know it. It probably just went bad, there were quite a few failures even with the aftermarket ones a year or two ago. Glad you got it fixed cheaply tho, that's the most important part!
Yes, I am very happy and feel I lucked out with how expensive and time consuming this could have turned out.  I have an extra 3 bar MAP Sensor in EcoHell now.
Posted this on other forums..so why retype the same information.. hopefully every one had a great July 4th.  Enjoy..
Ok.. it has been a while since I posted here. But more mods have been installed on EcoHell.  I had my hands full with my 9+ month old puppy (Thor), at the shop, so pictures were a little scarce..I will take more and update.  Any hoot.. enjoy..
Even Thor was impressed with the Steeda Anti-Sway bar...HA!
Installed Bilstein B6s all around..
Replaced the Transmission Torque Strut with Tony DiCunzolo's version...
Stock:
Tony's:
Also an oil change, new plugs and the other day, I installed the sequential mirror turn signals.
Stock:
Tony's:
How are you liking the ride with the new shocks struts and the H&Rs?  Any noticeable difference before and after the new B6s?  I have a set of H&R's sitting in my garage at the moment, but I'm back and forth on having them installed or going with a set of Steeda's instead, since they apparently don't require the camber bolts or anything else.
Stock:
Tony's:
Sorry for the late response.. I am still in Florida...survived Hurricane Ian with minor house damage.  Have not been doing much driving, but driving from NY to FL I loved the new responsive drive.  I am happy that I did the modifications.. it is night and day with the difference, also with the Torque Transmission Strut install as well.
Happy 2025 everyone. I hope the year has been good to you. I have not posted here in a while and all I can say is things have changed. Not that this will be my last post, as I can see myself purchasing a ST in the future, but between traveling to Florida and New York which happens about 3-5 times a year, I needed a new(er) vehicle for my travels. EcoHell was definitely a pleasure driving long distances even with all of my mods.
Now lets go back to December 2024, I was at the Audi dealership with wifey's car getting its routine oil change. Seeing my salesman (Jason) while waiting, I inquired about his best price for the Prestige SQ7 on their showroom floor. Knowing what my garage has and had, he introduced me into another vehicle and said I can offer you the same price as the SQ7. Say hello to GlacierHell..
I drove to Florida in early March, after getting her wrapped and new wheels/tires. I could only get 18 MPG in ECOHell during my highway runs, but this beast was getting 22-23, almost hitting 24 on the way back to NY.
And lastly, how often does one get three RS's in a photo...
So, what does all this mean for ECOHell? It means that ECOHell is no longer in my garage and given to my Uncle in Florida. The good part is that my Uncle is in his 80s and it stays within the family. And yes, when I had her detailed, I was thinking...WTH am I doing... ECOHell is one sexy vehicle..
