NEW SAFTY TIP FOR METH OPERATORS!!!!
Last time at the track I was skipping and missing at high rpms!? After 3mo to find out why, I dropped the bumper and there was a GAL of WASHER FLUID in my METH TANK!!!!!!! I check with my dealer and a newbie did my oil change. He said that my METH CAP look like it was a JOKE!!! So I added a lock to keep washer fluid out of it!!!!!
METH CAP w/LOCK
WASHER FEED TANK clear as day!!!
You can't miss the two, they are side by side!!!
Wow, that's crazy.
So you guys put your meth in the OEM washer fluid tank and then add a new tank for the washer fluid?  Always wondered what you did for the washer fluid!
PokerMunkee said:
Wow, that's crazy.
Yes the tank with METH kit is less than a GAL and washer tank is more than 2 GAL, Reason for the which.
left tank meth kit right washer tank.
First of all, that is hilarious.
I'm chuckling that the service tech, I guess, poured washer fluid into both? Or did he decide at the bewildering option that the reservoir labeled "Meth Only" was likely the better choice than the one with the universal symbol for wiper washer fluid?
Your signage on the reservoir cap is hilarious. You should type it out on a label maker or something, to make it look a little less...rudimentary.
You mean kind of like this iHeart? Any better than shoman's?
I labeled / marked my (Meth) reservoir a lllllllllong time ago for this very reason the OP encountered......
Mike I labeled my cap 2days after I INSTALLED the kit, and year and a 1/2 later this happen. So the lock. Mike you cap (not label) does not look stock? What is it?
