AJP turbo said:You seem like the type where problems just follow you around...the chances of the frequency of the problems you described are pretty impressive...have you ever pondered why other the rest of the country didnt share your experiences..yeah i know all your buddies had the same issues and it was all over the forums too.....if i look on the internet i also find that my town is inhabited with aliens too
ZSHO said:img width=400 height=190]http://i.imgur.com/iicuuXF.jpg?1[/img]
I have seen many members driving with no engine cover on,especially in hot weather & Track without any incidents including myself. Zsholxgt said:ZSHO said:img width=400 height=190]http://i.imgur.com/iicuuXF.jpg?1[/img]
Thanks Z! That's exactly what I wanted to know.
Any problem with that foam block staying in place with the engine cover removed?
bpd1151 said:Back in early 2011, there were failures of the HPFP due to that foam block being in place.
It actually RETAINS HEAT, not the converse as discussed here.
One of those failures occurred on Kirk Doucette's SHO.
Most of you know Kirk's involvement in the SHO world, spanning many decades.
Kirk also has direct insight with the entire engineering development team that built the Gen4+ SHO platform.
Kirk learned the only reason that foam block was put in place, was simply for noise suppression. That's it.
I removed the foam block on my SHO that same year (2011) & threw it in the garbage. Never have had it on since, and nor have I had any problems either.
My original engine cover does... But a Ford factory replacement purchased for a CF wrap does not... Pros and cons related to noise and heat I suppose.Ryan02Stang said:When changing the spark plugs on my MKS this weekend...i noticed there was also "foam" of some sort under the upper intake manifold/plenum. Do SHO's have that?
Never seen anything like that before...
Ryan due post some pic's of the location,question in mind,thanks. ZRyan02Stang said:When changing the spark plugs on my MKS this weekend...i noticed there was also "foam" of some sort under the upper intake manifold/plenum. Do SHO's have that?
