Polski Meth Kit
polskifacet said:
factory pump setting is between 265 and 280 psi. Asking snowperforamnce.net if I should turn it down.
It seemed excessive .. Maybe SBS can comment on his flow and pump rates?
Snow got back to me already and they recommend leaving the factory setting with the nozzle size I have.
hmmm I DISTINCTLY remember one of our regulars with a ton more mods than you and I quote a flow rate of about 1 gallon per 15/minutes.
Lets wait on SBS but 20 -30 psi pressure differences only equal about 30 ml/min. I assume his pump is fairly high pressure and he is using a m15 nozzle which is 3 times more flow than my nozzle.
The Alky Control pump pushes over 250 psi... plus as previously stated I have the M15 nozzle... I don't have a meter inline to tell me what my rate of flow is but it varies with the boost...
I know for a fact that I can max out and then some the amount of fuel the  ECU will pull which is 29% of the total fuel injected at WOT. Then my AFRs drop like a rock...
But I adjust the kit so I don't have knock... so I monitor KR... once I adjust the controller so there is no knock I am done... how much meth I am pushing? Dunno... I am sure you could do the math based on the datalogs... but I don't care...
Last log with Brad showed me holding over 255kpa (22.7 psi) with perfect fuel pressure over 2200 psi and AFRs holding nicely.
22+psi spike or constant?
I have been thinking since the 15-psi build I was running was 'to hot' i might be able to go back to it with 30/70 meth.  That would be awesome since the 15[psi build was way more torquey and seat of the pants fun at low speeds.
Follow up edit question.  on 'Race days' are you dropping the 'on' requirement to a lower pressure/voltage?  I was wondering on track days if there would be any benefit to setting the meth switch to 4 or so pounds to start the spray when brake torquing.
Don't know your timeline but I will start installing more wiring today. Taking my time since I'm wait to get my x3 back from sct. ill post everything valuable here.
Excellent .. good luck and take lots of pix.
We had an interesting effect when Brad modified one of the torque tables..... the ECU was setting dsd tip to 255kpa... in third gear I was holding 255kpa for over a second without any impact to fueling... it was not intended... but it goes to show you how stout the Alky system is...
Here is my take... LMS was one of the first groups to throw meth at these cars (at least I believe so) and they don't do anything that's half assed... if they are good with the pump and nozzle setup, then it's probably extremely sound..
With the 10+ meth revs I have played with, I can without a doubt say that with the Alky Control setup, you can hold over 2200psi at the rail with any load you throw at the motor with stock turbos. Assuming 100% meth of course. At this point I see no need for a bigger HPFP...
I am curious about a full tank of E85 with meth injection... if I can offset 30% of fuel now... no reason I couldn't run full E85... it would just be curious how much load I can push with it..
You could blow the motor sky high due to too much torque and still maintain 2200psi at the rail.
Snapshot of datalog attached...
Dark Blue = Fuel Rail Pressure
Light Blue = STFT
Grey = Manifold Absolute Pressure (boost)
Gold = AFR..
Meth = should have done it sooner...
Yeah,  full e85 + meth sounds risky.  I fear the connecting rods and block would not like that very much.  You'd have to treat the PTu as a throw-away on track days :P  .. even if you adhere to GM underrating their parts the the 6t80 (you could swap in i believe) would puke its guts out at 700+ ftlbs.
For our needs (tophersho and myself), the m5 nozzle is probably ample. With higher water % you need a smaller nozzle than 100% meth would need. I think I'm at a good starting point.
Eh, honestly, I just want 475/475 with consistent shifting and drive-ability.. I believe I am pushing more than that right now... but the point is... you can question the M15 with the Alky pump.. but the setup is very well thought out and tested.
Na not questioning it per say,  just trying to gauge what flow is good or bad.  clearly I will need to test,  but that will be super easy at the track.  No re-tuning needed just need to keep turning it up in small increments until it no longer has any additional effects.
Your insight and beta testing btw is keenly appreciated!
Found some real world tests of various nozzles.
I just want to make sure the record is straight here, while I appreciate the recognition, what I am doing is not beta testing. MANY others have gone down this path. Meth tunes have been out for a very long time. Torrie and LMS have both successfully tuned MANY MANY meth injected SHOs since probably 2010-2011....
Where in theory it could be beta testing would be with Brad tuning for meth in particular. While he has said there were a couple people he worked with before, I believe I am the first SHO he has had a chance to dig into. Since this is a play car for me, I am very liberal in the amount of testing I am willing to go through...
Hoping some of it will benefit others who choose to tune through him...
