SHOnUup said:I'm running 255/45/19 tires...how much would that affect the gearing compared to the 45/20 setup?
Rich
Thanks...maybe this is the reasoning behind the gearing change? PP models are all 20" wheels right?ajpturbo said:SHOnUup said:I'm running 255/45/19 tires...how much would that affect the gearing compared to the 45/20 setup?
Rich
Without plugging the values in ad say u might be pretty close to offsetting the gearing and being similar to what the pp is because u are gaining a mechanical advantage due to your tire diameter being shorter
ZSHO said:The answer is very simple without the back and forth discussions which clearly sounds gratifying to you based on your other post,there are plenty of options like trading in your non-PP for a PP just like i did,hope this helps you out.
IHeartGroceries said:You bought a sport lux car, with wonderful power. As if having no manual trans option isn't bad enough, if the inability to defeat traction control really isn't a problem, that's incredible!
That's like having the world's fastest supercomputer with no mouse or keyboard to use it! Lol
Dxlnt1 said:... Someone posted on this thread the top end for PP was 122 mph and Non as 140 mph.
SHOnUup said:Thanks...maybe this is the reasoning behind the gearing change? PP models are all 20" wheels right?
Rich
SHOnUup said:If this is all about performance, shouldn't there be a tuned side to the debate. The majority of us are running tunes here. I'd just like to hear some thoughts on that side of the spectrum. Like downsizing wheel size and stuff to add sidewall flex for grip. And, is turning off the traction control completely better vs just turning off the grannies, assuming that's what us non pp folk do.
Not trying to discredit your, what I see as a great open minded thread of discussion. Just adding another dimension.
Rich
Popular Mechanics
Chrysler 300C AWD vs. Ford Taurus SHO
Sep 30, 2009
http://www.popularmechanics.com/cars/a12885/4322127/
Chrysler 300C AWD
Base price $39,925
Powertrain 370 hp/398 lb-ft, 5.7-liter V8, 5A
Wheelbase (in.) 120.0
Length (in.) 196.8
Width (in.) 74.1
Axle ratio 3.07
Weight 4280
Brakes (f/r) 12.6-in disc/12.6-in disc, ABS, ESC
Tires (f/r) P225/60R-18
ACCELERATION (sec)
0-30 mph: 2.0
0-60 mph: 5.5
0-100 mph: 13.9
40-70 mph: 4.2
20-60 mph rolling start: 4.4
Quarter-mile: 13.9 @ 100.3 mph
BRAKING (ft.)
30-0 mph: 30.4
60-0 mph: 126.2
EPA fuel economy (city/hwy) 16/23 PM Fuel Economy 21
Ford Taurus SHO
Base price $37,995
Powertrain 365 hp/350 lb-ft, 3.5-liter V6, 6A
Wheelbase (in.) 112.9
Length (in.) 202.9
Width (in.) 76.2
Axle ratio 2.77
Weight 4368
Brakes (f/r) 12.8-in disc/13.0-in disc, ABS, ESC
Tires (f/r) P245/45R-20
ACCELERATION (sec)
0-30 mph: 2.2
0-60 mph: 5.4
0-100 mph: 13.3
40-70 mph: 4.9
20-60 mph rolling start: 4.2
Quarter-mile: 13.7 @ 101.7 mph
BRAKING (ft.)
30-0 mph: 29.9
60-0 mph: 117.6
EPA fuel economy (city/hwy) 17/25 PM Fuel Economy 22
All about that torque band.14 TUX BL said:In a way, it doesn't figure ...
The 300C Hemi makes 5 more hp, 48 more lb-ft, weighs 88 lbs less, and has better gearing. Yet it was slower in 0-60 mph, 0-100 mph, 20-60 mph, 40-70 mph, the quarter mile, and had worse braking.
Chrysler throwing cubic inches around with not so good results...lol14 TUX BL said:In a way, it doesn't figure ...
It's all that torque at 1700 rpm. Plug your dragstrip numbers into a 1/4 mile to hp converter and you will see what I mean.14 TUX BL said:In a way, it doesn't figure ...
For sure...our HP #'s get horrible estimated times. Then I plug in times to get HP and it's up around 500 hp.FoMoCoSHO said:It's all that torque at 1700 rpm. Plug your dragstrip numbers into a 1/4 mile to hp converter and you will see what I mean.14 TUX BL said:In a way, it doesn't figure ...
SHOnUup said:For sure...our HP #'s get horrible estimated times. Then I plug in times to get HP and it's up around 500 hp.FoMoCoSHO said:It's all that torque at 1700 rpm. Plug your dragstrip numbers into a 1/4 mile to hp converter and you will see what I mean.14 TUX BL said:In a way, it doesn't figure ...
Rich
