AJP turbo said:Sorry to hear Topher. I feel like you have had more bad times than good with this car.
And I think some of the programming for the TCU happens when you flash the ECU but I really don't know. I"m sure the dealer can do trans programming with the IDS software they use but I really don't know.
Btw, the 2010 models do have a drain plug per se.TopherSho said:SHOme said:How often do you have it flushed? I do mine every 30k because my 2010 TC went bad at 112k. It might be the PTU fluid also.
Sent from my XT1585 using Tapatalk
2010 has no plug that I can access, and the dealership refused to change the lifetime fluid.
bpd1151 said:Btw, the 2010 models do have a drain plug per se.TopherSho said:SHOme said:How often do you have it flushed? I do mine every 30k because my 2010 TC went bad at 112k. It might be the PTU fluid also.
It's the port that they hook up to pressure check the system. I drain mine twice per year by means of this bolt.
If you need a pic, LMK.
bpd1151 said:The trans itself has a drain plug.
The PTU does NOT.
I just thumbed through more of the thread, and was confused as the title says, trans blew, but looks like discussion transitioned to the failure possibly being the PTU.
Not sure which one you've verified has failed.
A mighty vac pump with an extended tube is used to change my PTU fluid. Takes approx. 20min total. I'm thinking the dealer just didn't want to perform the service.
Do yourself a favor and get the trans serviced while it's there.TopherSho said:Verdict is PTU, a "inspector" for the warranty is coming to look at it in the next 48 hours. My fingers are crossed a little bit.. HOPEFULLY the car will be on the lift still where nothing will show of the meth kit ..
TopherSho said:OMFG .. THE SMELL .. WTH??? Seriously do they take urine and feces from demons, dead cats, meth and cram them into these units?
this is the most awful thing I've ever smelled and I've taken apart a supercharger when I was dumb..
sm105k said:TopherSho said:OMFG .. THE SMELL .. WTH??? Seriously do they take urine and feces from demons, dead cats, meth and cram them into these units?
THIS! The fluid in the Eaton M90 was the worst.
lamrith said:PTU is best news it could be, they are relatively inexpensive all things considered. I opted to not get extended warranty because replacing turbo's and PTU was less than I would pay on an extended coverage warranty.
Crossing fingers for you that they cover it. They are a known weak point regardless of tune, so hopefully be straightforward process. From what I have read here they will hopefully replace it with the '13+ version so you can do flushes on your own moving forward.
