6500rpm said:All the failures I've seen in the fleet seem to point to cooked out thick fluid. Once the unit starts to fail it's toast. Most likely starts with gear failure and once there's metal in the system and poor lubrication it takes everything with it. Once the bearing integrity is gone-Bang!
802SHO said:6500rpm said:All the failures I've seen in the fleet seem to point to cooked out thick fluid. Once the unit starts to fail it's toast. Most likely starts with gear failure and once there's metal in the system and poor lubrication it takes everything with it. Once the bearing integrity is gone-Bang!
This is what I've been thinking, how many failures are not fluid related?
Which is why I decided to spend the little extra money on a great suction device to make the fluid exchange easier to do more often. Gear oil is cheaper than a new transmission
802SHO said:We need to start getting our non PP PTU units cooled
shoNoff said:I wish I still had the pictures. I changed my 13pp fluid at roughly 58k it was near a solid. It had the consistency of wheel bearing grease almost. I did 2 more changes before 70k and it got much better. There was never a ton of metal. I may have just caught it in time. I agree the heat of the downpipes baking the fluid.
SM105K said:shoNoff said:I wish I still had the pictures. I changed my 13pp fluid at roughly 58k it was near a solid. It had the consistency of wheel bearing grease almost. I did 2 more changes before 70k and it got much better. There was never a ton of metal. I may have just caught it in time. I agree the heat of the downpipes baking the fluid.
But did it fail? I kid, I kid. This is very interesting to say the least. I am not saying the PP PTU don't fail, I am saying they have a better track record of not failing possibly because of being cooled.
I am working on my DP's this week. The guy that does my fab work became unavailable. So I am going to wrap them up and install them this weekend. I want to safe guard the PTU at all costs.
My experience with CO2 comes from 10 years of playing for a promotional paintball team in the 90's/2000's. The problem is when you dump a lot of CO2 quickly it changes states from a liquid in the tank to a solid (dry ice). With the markers it lead to extreme pressure drops, loss of velocity which is why high pressure nitrogen systems came into play. I don't know if you could have a tank that was big enough to spray any length of time without causing this.802SHO said:Interesting. I've been fascinated recently with using co2 to cool the intercooler. I wonder what else can be cooled.
802SHO said:I just quickly read something else entirely about using No2 or Co2 to cool the intercooler. Saying residual gases can get into the intake and Co2 leading to power loss that way or No2 causing an untuned for increase in power.....seems like there's always a snag with these type of things.
Well I think the most cost effective direction to go would be to attack the downpipes with a thermal coating....and then top it off with an exhaust wrap....now I bet that would dramatically reduce the heat and naturally not transfer to the PTU. Better than nothing
https://www.summitracing.com/parts/zyc-10004?seid=srese1&gclid=CjwKCAjw1f_pBRAEEiwApp0JKJ2hjk7HUe22BqSxfR1agAscarSiw6LUA5Pc0z0TKIKbY1vRBphgbhoCRKUQAvD_BwE
SM105K said:802SHO said:I just quickly read something else entirely about using No2 or Co2 to cool the intercooler. Saying residual gases can get into the intake and Co2 leading to power loss that way or No2 causing an untuned for increase in power.....seems like there's always a snag with these type of things.
If you want to cool the charge air, you need to use a small shot of nitrous with a dry shot fogger. If you have the fuel capabilities that will be your best bet. It tanks the intake temp which increases air density, which in turns gives the ability to burn more fuel because of the chemical reaction and increased oxygen levels, and the result more POWA. I would run it directly post turbo. There are numerous disagreements about this regarding pre and post turbo, but I have had success directly POST turbo.
When I first put my blower on my 5.0 Fox Body Mustang, it did not have intercooler. To cool the charge air, we tapped a fogger post SC head with a .026 jet (very small) and the car picked up 58 rear wheel hp.
802SHO said:SM105K said:802SHO said:I just quickly read something else entirely about using No2 or Co2 to cool the intercooler. Saying residual gases can get into the intake and Co2 leading to power loss that way or No2 causing an untuned for increase in power.....seems like there's always a snag with these type of things.
I like this idea. Tiny nozzle and a super cool charge....and by default make a little more powa....how "little" we shall see.
Blacked out Taurus approaches the staging lights at the Dragstrip....purges the No2 lines.....jaws drop
802SHO said:You also have a lot of experience with nitrous too. Your knowledge is much appreciated and I think Nitrous gets a bad rap bc ppl don't do their homework and misuse it...then turn around and talk a bunch of crap about it. Like with methonal. It works extremely well and is relatively safe if it's set up properly and used accordingly.
