Exactly how I want to do mine. Did you use 5/16" ID hose?SHOme said:Picture of new vent location.
SHOme
Sent from my Speak and Spell
SHOdded said:Wraitherx's experience with his 2014 Perf Pk SHO
http://www.ecoboostperformanceforum.com/index.php/topic,8081.0
SHOme said:My fluid was way thicker than that at 30k. It was and it was still thicker than the video but not as bad as the first time. I had the same issue getting fluid in thru the vent tube I added. I was thinking if I slide a very small tube down the vent tube into the PTU and long enough to stick out of the funnel that would let the air out(slowly) while it filled. I found a roll of small diameter heat shrink tubing that I might try next change. I'll post pics if it works. I also thought about poking a small hole in the bottle so it drips and hanging it over the funnel and just let it drip overnight.
SHOme
