RDU Ratio
Wikipedia has some answers:
https://en.wikipedia.org/wiki/GM-Ford_6-speed_automatic_transmission
Brucelinc said:
That is the final drive.....I don't think the ring and pinion in the rear needs to be the same....The focus RS is different and the clutch packs handle the torque delivery I think.
So, if I was to attempt a top end run should I use 4th or 5th gear and what is the max RPM that these engines can reach?
    Auggie
    Auggie
Probaly 6th....why would you think 4th or 5th
In order to calculate the speeds of each trans gear with the 2.77 rear gear I will need to know what RPM these engines perform the best at. In other words the max RPM at each shift point. I don't think there is enough HP to pull 6th gear for top end ?
  Auggie
There isnt enough power to pull top speed in top gear in most cars...and the gear before top gear is usually too short...so drag limited in top gear is usually where it happens
Auggie, you can calculate all you want but if you really want to know then get out there and do it...cant change the final drive and i dont think changing the shift point will help much
Yup AJ your right and I will do just that. But in the mean time I want to know what gear will give me the best results. If I use 6000 RPM(tach has a red line at 6500) here's what I came up with.
Engine RPM = 6000
Tire Diameter = 28.0"
Gear Ratio = 2.77
Trans Gear Ratios = 4.484, 2.872, 1.842, 1.414, 1.00
4.484 = 40.3 MPH
2.872 = 62.9
1.842 = 97.9
1.414 = 127.7
1.00 = 180.5  SO: To go 140 MPH + I would use 5th gear and have to reach at least 4800 RPM. It would be nice to change 5th gear to a 1.200 ratio at 5800 to go a 140.0 +. I wonder if the engine would be able to keep pulling past 4800 RPM in 5th gear to go 150.0 MPH + ?
    Auggie
Yup, the 3.16 rear gear ratio would have been an advantage. Are there aftermarket gears available?
    Auggie
