Rock Auto Closeout
Not much of a Rock Auto fan. They sent me the wrong mounts for the front struts for my Mustang and since I didn't discover it within the 30 day return window, I am out of luck...doubt that I will ever again purchase anything from them.
Motorcraft 13+ PP-SHO Brake pads BRF1435, DG1Z2001E, DG1Z2001F  . Z  :)
$34.79
https://www.rockauto.com/en/moreinfo.php?pk=5808957&cc=1503823&jsn=514
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,brake+&+wheel+hub,brake+pad,1684
I received a couple of PM regarding the Promo-Code and hopefully Megan from www.rockauto.com should supply us with a new Promo-code applicable to the Forum soon! TIA.  Z  :)
5% Discount Code: 2E9FDD0E8E7361
Expires: September 28, 2018
I would assume these compare favorably to the OEMs.
In my Nissan Juke. OEM NGKs are pretty much the only plug you use. People have tried others and they dont do well with the Turbo engines. They are also very $$$. Like $15-$18 each.
I tried one step colder and that failed even tho I am at 280+ whp at 21psi.
Used OEM is laying next to the one step colder 2mm shorter plug and the cold plug is the orangish one. One tank full of fuel.
New Discount Code  9054464683451274
The discount takes 5% off our reliably low prices. There is no limit on order size or the number of orders.
This discount code expires on October 21, 2018 .  Z  :)
www.RockAuto.com. Discount takes 5% off our reliably low prices. There is no limit on order size or the number of orders. Use the code for your next order, and share the code with anyone you know who works on cars or trucks.  Z  :)
This discount code expires on December 9, 2018
9379551188826095
TIMKEN HA590478 Front Wheel Bearing & Hub Assembly
for 13+ Performance Package SHO. Z
Promo-code ^^^
$127.79 - ea
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,brake+&+wheel+hub,wheel+bearing+&+hub+assembly,1636
https://www.rockauto.com/en/moreinfo.php?pk=4975638&cc=1503823&jsn=621
ABS/Non-ABS (Y/N) N
ABS Type Encoder
Bearing Type BALL
Bolt Circle Diameter B (in) 4.494
Bolt Circle Diameter H (in) #
Bolt Quantity 4.000
Bolt Size (in) M12 x 1.5
Brake Pilot Dia (in) 2.678
Driven_Non Driven Driven
Flange (#) 2.000
Flange Diameter (in) 5.739
Flange Offset (in) 1.690
Flange Shape Trapezoid
Generation Type X
Hub Pilot Dia G (in) 3.823
Lug Bolts_Bolt Holes (#) Y
Roll Form (Y) Y
Spline Quantity 38.000
Wheel Pilot Dia (mm) 63.250
Wheel Stud Qty 5.000
Wheel Stud Size (in) 43832.000
Compare to the Amazon price, this is a steal!
https://smile.amazon.com/Motorcraft-VC10A2-Anti-Freeze/dp/B008B5VBBS/
I believe the 2010MY & 2011MY which have a Build Date before 7/11 use the exclusive Green coolant IIRC!
The rest use the orange coolant to simplify things.  Z  :)
