Rock Auto Closeout
MAHLE F32679 7T4Z9450AA Multi-Layered Steel
ID 2.25in; Left or Right Exhaust Flexible Pipe to Underbody Catalytic Converter. Z
$6.38 - ea
https://www.rockauto.com/en/moreinfo.php?pk=7673752&cc=1503823&jsn=10587
MAHLE F32686 AA5Z6L612A Multi-Layered Steel
Converter; ID 3.00in; Left or Right Turbocharger to Catalytic Converter.
$6.51 - ea
https://www.rockauto.com/en/moreinfo.php?pk=7673764&cc=1503823&jsn=10588
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,exhaust+&+emission,pipe+flange+gasket+/+seal,5836
Www.rockauto.com Discount code below.  Z
96493055919127
The discount takes 5% off our reliably low prices. There is no limit on order size or the number of orders. Use the code for your next order, and share the code.
This discount code expires on January 13, 2019
DORMAN 939192  - DG1Z1015A Steelies. 18 In . Z
$107.79 - ea
GRAND TOTAL OF $463.56
Backspacing 169 MM
Bolt Pattern Diameter 114.3 mm
Bore Diameter 63.6 mm
Center Cap Included No
Color Black
Dimensions 18 x 8
Grade Type Regular
Load Rating (lbs) 1675 Lbs.
Lug Hole Diameter 16.5 mm
Lug Hole Quantity 5
Offset (mm) 51 mm
Package Contents 1 Steel Wheel
Primary Bolt Pattern 5 x 114.3
Split Type No
Tpms Compatible Yes
Valve Stem Diameter 11.5 mm
Wheel Diameter (in) 495 mm
Wheel Finish Painted
Wheel Material Steel
Width (in) 236 mm
Alternate/OEM Part Number(s): DG1Z1015A
https://www.rockauto.com/en/moreinfo.php?pk=10354140&cc=1503823&jsn=10&jsn=10
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,wheel,wheel,7644
STANDARD MOTOR PRODUCTS RY1712 Alternate/OEM Part Number(s): AA8Z9D370A, AA8Z9D370B FUEL PUMP RELAY   Z
$43.99
Connector Gender Female
Connector Quantity 1
Connector Shape Rectangular
Mounting Bracket(s) Included Yes
Terminal Gender Male
Terminal Quantity 8
Terminal Type Blade
Voltage 12
https://www.rockauto.com/en/moreinfo.php?pk=5413512&cc=1503823&jsn=10559
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,electrical-switch+&+relay,fuel+pump+/+circuit+opening+relay,3380
