Really?Code AiR said:I think it could be a little lower. I am not "really" happy with the height but it's my daily so I don't rub and have full function. So it is what it is. The space in the rear is really bugging me with my new Roti's. Wheel specs; f20x8.5 / r20x10 .... Tire specs; f255/45/20 and r275/40/20
FoMoCoSHO said:Really?Code AiR said:I think it could be a little lower. I am not "really" happy with the height but it's my daily so I don't rub and have full function. So it is what it is. The space in the rear is really bugging me with my new Roti's. Wheel specs; f20x8.5 / r20x10 .... Tire specs; f255/45/20 and r275/40/20
I'd be unbelievably happy how the drop and wheels turned out, its perfect!
Is yours a PP on non-PP?
dubcitySHO said:Do you have adaptive cruise control? Performance pack cars don't offer it and it's the easiest way to tell on the 10-12 MY's from a visual stand point.
But not all vehicles without ACC are PP vehicles. Push and hold your traction control button for 5 seconds or so, and if the gauge cluster reads something along the line of "Advancetrac Sport" or "Advancetrac Off", you have a PP vehicle.
IMHO from the color scheme to the wheel setup wouldn't even care if its a Performance package or NOT...from my perspective it simply looks that dam good! enjoy. ZCode AiR said:FoMoCoSHO said:Really?Code AiR said:I think it could be a little lower. I am not "really" happy with the height but it's my daily so I don't rub and have full function. So it is what it is. The space in the rear is really bugging me with my new Roti's. Wheel specs; f20x8.5 / r20x10 .... Tire specs; f255/45/20 and r275/40/20
Honestly idk lol. How do I tell?
ZSHO said:IMHO from the color scheme to the wheel setup wouldn't even care if its a Performance package or NOT...from my perspective it simply looks that dam good! enjoy. Z![]()
@ dubcitySHO That candy apple SHO of yours leaves nothing to be desired. Z :thumb:dubcitySHO said:ZSHO said:IMHO from the color scheme to the wheel setup wouldn't even care if its a Performance package or NOT...from my perspective it simply looks that dam good! enjoy. Z![]()
My thoughts exactly. I've always loved the Cinnamon and the wheels definitely make it pop even more.
Plus once you get a tune the gearing advantage of the PP more or less disappears.
It matters when you have an MKS and you are gathering impressions of the different suspensions on H&Rs before a final decision is made. The MKS gets base shocks so the only upgrade path is to rob the SHO parts bin or coilovers. I do not want to put a third suspension on because I chose wrong.Blackhawk said:Factory 19s, good chance it isn't a PP unless someone swapped them previously. Doesn't really matter much anyways in the grand scheme of things.
FoMoCoSHO said:It matters when you have an MKS and you are gathering impressions of the different suspensions on H&Rs before a final decision is made. The MKS gets base shocks so the only upgrade path is to rob the SHO parts bin or coilovers. I do not want to put a third suspension on because I chose wrong.Blackhawk said:Factory 19s, good chance it isn't a PP unless someone swapped them previously. Doesn't really matter much anyways in the grand scheme of things.
I had two gen 5's one PP, one non, and I much preferred then standard package. IMHO not enough of a performance increase to justify the harsh ride.
ZSHO said:@ Codeair is there a spare tire in the trunk? Z
ZSHO said:IMHO from the color scheme to the wheel setup wouldn't even care if its a Performance package or NOT...from my perspective it simply looks that dam good! enjoy. ZCode AiR said:FoMoCoSHO said:Really?Code AiR said:I think it could be a little lower. I am not "really" happy with the height but it's my daily so I don't rub and have full function. So it is what it is. The space in the rear is really bugging me with my new Roti's. Wheel specs; f20x8.5 / r20x10 .... Tire specs; f255/45/20 and r275/40/20
Honestly idk lol. How do I tell?![]()
SHOdded said:No water to air coolers, assuming you are referring to the intercooler, in any SHO thus far; it is all air-to-air, hence the need for aftermarket solutions. The advantages of PP really manifested with the Gen 5 because of the upgraded oil and trans fluid coolers, which can be used in Gen 4 applications, thanks to the detailed writeups by bpd. Noone has attempted a radiator upgrade thus far that I know of, though I THINK bpd has upgraded fans?
A stroll through the HOWTO section is a good way to generate some ideas to make your Bull more ferociousand lighten your wallet (helping your ET's)!
https://www.ecoboostperformanceforum.com/index.php/board,107.0.html
