avidmotion said:Ok, nearly done....I used the horn spot in front fender. I didn't want to drill. I didn't want to hack the stock hoses.
The right port goes to rear valve cover with check valve inline. I have the CSS . So hose off front valve cover to charge pipe. Valve cover capped.
So RX CSS oil filler cap hose has check valve and goes to T on fitting coming out of charge pipe. Other side of T goes to other outside fitting on the can. I used the vacuum from the intake manifold to the middle port on the can. I needed 4 ft of hose and got clamps for the check vales and T....I love have pics and better write up later when my mechanic finishes up and gives me the pics.
Excellent explanation MiWiAuMiWiAu said:avidmotion said:Ok, nearly done....I used the horn spot in front fender. I didn't want to drill. I didn't want to hack the stock hoses.
Did you see the schematic in post #135? If I'm interpreting your installation correctly, you have port "C" running to the rear valve cover? The center port "B" should be running to the rear valve cover.
Ports "A" and "C" receive a vacuum (flow away) from the can and pull the "dirty" air in to port B (center port) from the rear valve cover - NO CHECK VALVE REQUIRED on the center port, since this should only be flowing in one direction at all times (into the can). One of these, A or C (doesn't matter which), should pull from the side of the intake manifold. The other should pull off the charge pipe(s). When hooked up properly, the can will always be pulling vacuum into either Port A or C. When under boost, vacuum will come from the charge pipes, when not under boost, the IM.
EDIT: Check out this image: http://www.rxspeedworks.com/wp-content/uploads/2015/08/rx-catch-can.jpg
Per an e-mail exchange I had with RXP, under normal operating circumstances, the CSS will pull vacuum (fresh air). Their diagram shows the css being installed in the top (clean) side of the airbox where vacuum is minimal. If memory serves, without reading back through the entire thread, I think JimiJak re-routed his CSS from the charge tube to the airbox. If you want to keep yours installed on the charge tube, make sure the check valve points towards the CSS, otherwise you might pull oil from the valve cover under boost. I vented my CSS to atmosphere with a small push-on filter - I'll try to get pictures posted later tonight. I will only install a check valve if I notice crankcase vapors in my garage.
ZSHO said:Definitely some pic's will be viable in the process. Z
avidmotion said:progress on hold, we misunderstood the flow of the can, and direction of flow. In my set up, obviously fouled, I thought we were to pull the vapor from the valve covers, and the intake manifold pulls vacuum out of can....this is wrong arrows on check valve go away from can, and I got the middle port and "c" ports crossed. And I need to drill the top of airbox and skip the T. Everything at stock to I figure it out tomorrow, take new pics, document and see if it starts. Thanks for the. Once it all good I makea sticky for the SHO, a little different then the trucks.
 Z
 ZColorado-SHOBro said:Resurrection once again!! haha
Just purchased JJ's RX standard can kit and am already busy planning the install. Couple general questions. From reading all the how to threads etc. it looks like the options are- (please correct me if any of the following is false)
Clean side setup:
1.Vent CSS to atmosphere w/breather filter(which tends to get oil soaked and leak vapor in the cabin)
2.Tap into the airbox (which could accumulate oil in the airbox unless a check-valve is used?)
^if tapping into the airbox does it need to be pre or post filter?
Can the CSS be removed and factory oil cap replaced while still leaving the dirty OCC side connected without harm to the operation of the system? This would be to avoid red flags on dealer visits.
Vacuum source:
Was it ever determined if both areas of the charge pipe(front side OEM port+rear BOV port) need to be used with the T or is one vacuum source sufficient?
^the answer to this question might determine if it's possible to run the system with the factory oil cap as a the OEM piece from front cam cover to charge pipe source would need to be installed when doing so. . If i'm not mistaken.
Did my best to get up to speed on everything before posting so hopefully the questions are clear.
Thanks to all members for their in-depth documentation of installs and results! Great community here!
Thanks for the reply Mikey. Yeah i ended up reaching out to Tracey and he answered those questions for me. Everything you stated is accurate.MiWiAu said:Colorado-SHOBro said:Resurrection once again!! haha
Clean side setup:
Vacuum source:
Hey Nutz, sorry I missed your questions here. A little tardy with my reply, but in case someone else comes along...
Re: CSS
1. This is how I have mine. I have not noticed any offensive vapors or oil on my filter yet.
2. You want to tap the clean/filtered (top) side of the lid, so you are not pulling unfiltered air into the engine.
Re: Vacuum source
On the intake pipes, I recall seeing a post from Tracy (original designer of RX can) that one intake connection is okay, but two is better. Typically, a single connection would be on the fore most pipe where the cleanside quick connect attaches, for ease of install. A second source can help improve efficiency and provide, I imagine, slightly more vacuum and evacuation when under boost. I opted to use two intake sources for maximum evacuation.
Technically, you could leave the cleanside hooked up to the intake pipe and use the factory oil cap, but IMO, this still leaves a potential for oil to get drawn back into the intake piping. If a CSS breather filter is getting oil soaked, why would one expect oil to not migrate to the intake end of the cleanside tube? Once oil is in the intake, there's nothing keeping it from eventually getting to your valves, so on my install, I decided to completely remove that connection. The only way oil will enter my intake now is from turbo blow by. Hopefully I'm a ways off from that...
Colorado-SHOBro said:I remember reading earlier in this thread that some guys were experiencing oil/gas smells in the cabin and/or oil pooling in the airbox. I thought the cause of the smell in the cabin was from venting the CSS to atmosphere. Correct me if i'm wrong on that though
Right now i'm temporarily using a clear hose for the CSS so i can see if any oil accumulates from the burps transitioning into boost. 175miles on the system now and i haven't seen anything-also no smells in the cabin so smooth sailing
will do and thank you. i'm fighting the urge to empty the can but would rather get at least 500 miles on it first.MiWiAu said:Colorado-SHOBro said:I remember reading earlier in this thread that some guys were experiencing oil/gas smells in the cabin and/or oil pooling in the airbox. I thought the cause of the smell in the cabin was from venting the CSS to atmosphere. Correct me if i'm wrong on that though
I recall reading the same thing about fuel/oil vapors with CSS VTA. Lucky for me, this has not been my personal experience.
I'm subbed to your how-to thread, so keep us posted on your clear tubing observations (great idea)!
