RX OCC drain results
kbeck59
As of this time I have decided to go ahead a do a temporary ( for me) plumbing finish for the RX install using appropriate rubber fuel hose .
I Will keep a close eye on things and monitor engine oil and other vitals and check for fluid ( gunk ) accumulation in the can .
I see no compelling reason not to install the RX and can see absolutely no benifit to this gunk accumulating in the intake and IC and the possible harm such accumulation may do to other internal engine components
I see no Compelling reason now for Livernoise to comment because They really have no " skin in the game " and more than likely they do not want to get into another heated debate with another vendor .
I cannot fault them for that .
I know that many members have already purchased the RX .
Some have installed it already , some are waiting to do so when they have time and/or are uncertain about going on with the install . Many others have ordered one and have not recieved it yet .
I am Hoping This Thread can be used to collect accumulation info and maybe mounting alternatives that may make the RX work more effectively.
Many members have no desire to use this system or are exteremly doubtful to its effectiveness ..... To those in that catagory may I respectfully ask that you refrain from posting or at the very least to not make derogatory comments about the product.
THIS IS MEANT TO HOPEFULLY BE OF USE TO THOSE THAT HAVE CHOSEN TO BUY THE RX
I ask members to contribute there experience with the RX , any and all issues associated with its use .
Primary issue being can accumulation and and possible mounting solutions that may make it operate more effectively .
Excellent.
Pulled a CAC today to inspect and clean:
Not pretty, and a 2013 at that, but this is a F-150, not a Flex or Taurus.
RX system is on it now, so will show drain results in future and would also like to remove CAC and recheck (installed aftermarket unit).
Thanks in advance to all who can contribute to "real life" data for this product :thumb:  Mileage at time of check/emptying, general driving habits during that time, and oil analysis if any are some of my suggested data points.  Photos that illustrate intake/valve/IC/catchcan condition are also very welcome :)
Good thread.
I will be posting results on our 500 mile X Sport...RX shipped yesterday.
Looking forward to results from others and where they mount them.
Guy
The temp has been dropping here in NE Ohio recently. I decided to do a drain after about 300 miles since the last drain (almost nothing)
I didn't get this much throughout the entire summer.
So the lower temp definitely yield better results.
Also big thanks to Tracy (tuner boost) for sending me the new billet clean side separator and check valves.
How is the new seperator going to remedy all that excessive oil you had before being pushed all through the cleanside,thanks.  Z
How is the new seperator going to remedy all that excessive oil being pushed through the front clean side ,thanks.  Z
not sure if it will, only time will tell. The new style does not look like it comes apart. So I'll have to periodically check the css hose for oil.
