Sealing Airaid Intake (Take 2) Comparison Modded K&N vs Stock VS Modded Airaid
After sitting in miles of traffic, on Woodward, literally taking 15 minutes a mile in 70* temp. The mod was working great! 85* was the highest IAT1 reached and would drop instantly with some throttle.
Rolled around in first gear turning heads...
Awesome! Now that is what a CAI is supposed to do! Supply the engine with cold freaking air lol!
Thanks be with you guys once again.
The woman even asked a cop who was out there all day if there were any SHO'S cruising. He said yours, that's it?
Ok, I can't take this thread anymore! Ordered an Airaid from EcoPowerParts.com :D
Been trying to hold out for the other solutions, but everyone here having great results is too much for me to take. Once I saw Crash got excited, I knew it was time to order LOL.
Hopefully Airaid has your commission check in the mail.
Sent from my Lumia 1520 using Tapatalk
Be sure to get the upgraded stripping. The D style sounds best route.
Lol, I don't know of any vendor that would have done all this testing on a product. And if it has Crash's endorsement now you know it's gotta work.
I think I can get my hands on a heat reflective paint that works on plastics. I'm going to approach Airaid to see if they will part with a unit for some additional testing. I would rather have a back up "just in case". We will see what the have to say.
http://www.zircotec.com/page/--thermal-protection/145
This stuff looks promising, if it's good enough for F1 applications should be good enough for our EBs. I wonder if coating the cold pipes before the turbos would have any impact on performance?
At a point do you worry about actually making the air warmer by insulating these pipes?
Wonder if it would be beneficial to do a ram air type deal in bottom grille that directs air up towards these pipes?
That can be a real problem, again something I noticed with the K&N. When I insulated the outside of the tube it was better until heat soak set in when the car was idle or after being shut off. The aluminum pipe took forever to recover. Something like this I would rather test on another unit. Like I said above. However my tests on the K&N were done with the unit drawing in hot air from the engine as there was no other choice. It is possible that the Airaid with it's fresh air source could overcome this. The other option would be to design a heat shield not directly attached to the pipe after the filter box. The transmission reaches temps of 90C after a few runs at the track.
Very nice find. Some cool looking products there. Flexible ceramic shields and the clamp on heat shields look promising.
This one looks good, and not expensive http://www.aircraftspruce.com/catalog/eppages/coolit.php
For a better alternative than the bubble type.
That seems to be a good price for a 2' x 4' piece. Wonder how the mylar side reflecting heat would effect raising temps on other stuff around it?
Don't know, I would assume that it would retain some of the heat. Only way to know for sure is to test it!
Ok everyone as I said I called Airaid on Thursday at lunch and yesterday the new seals came in the mail. I pulled the box today and am having my dad wrap it (he is retired and needs some projects lol. Thanks Pops if you are reading this) and I had him wrap his stock air box on his Ranger back in the day and it did wonders with IAT temp. I have asked this question before but still need some clarification. It seems that the shielding is used to reflect the heat away from the box so why is the inside being lined and not the outside. At a look it seems it will fit with the outside wrapped in the shielding. Just my two cents.Any advise and help is greatly appreciated
I personally didn't do the outside of box because I don't trust the adhesive on the insulation to stick for long under the high heat. I could be wrong in that assumption, but didn't want to risk something getting sucked into the fans.
I am going to use 3M trim adhesive. Spray it on the box and on the shielding let it tack up good the cover the seams with the aluminum tape. Then i will go from there. Thanks for the input.
I have tried insulating the exterior of CAI's in the past with mixed results. This is Cold Air Inductions CAI's
http://www.coldairinductions.com/catalog/product/gallery/id/88/image/439/
The also insulate the inside of the box. The clearance of the box to some of the hoses is really tight. Also with the barrier on the inside you don't have to contend with all that plastic once it becomes heat soaked.
