I recall a while back you mentioned you had some recalls,TSB'S performed on your car,if so were they performed after your 1st run on 5/14. ZShoBoat said:So I thought I would revisit this thread, as I have been thinking about my runs from last year. And why I was able to pick up a tenth from my personal best from last year.
Car is pretty much the same, weight was pretty much the same. 3/4 tank of gas, stereo was already in and still the same. The only real differences were tires, had F1 supercars vs the Michelin Pilot SS now and my modded Airaid intake VS the modded K&N Typhoon.
So on to the data.
May 10 best for that night was a 12.737, I have the slip for that one in my stack. Not sure on the specifics I do know that I had a really decent 60 at less than 1.85 (for F1 supercars lol).
Run Data
May 10th 2014
60 1.876
330 5.343
1/8 8.247
MPH 85.07
1000 10.734
1/4 12.834
MPH 108.59
From my runs last night a slip with a similar 60
60 1.860
330 5.263
1/8 8.119
MPH 86.65
1000 10.571
1/4 12.635
MPH 109.39
DA was right around 0 for last night. So again similar conditions to the May 10 2014 runs. I know what you are thinking, conditions, track prep blah blah blah. All I know is that she is faster than last year consistently. So a bit more Data to back up what some of us have already found out. What's not to like about Data he is pretty cool after all![]()
So are you saying you think airflow is choked at 5400 for the stock box?metroplex said:Thanks! That link helped a bit, but the modified Airaid doesn't seem to offer much of a power gain over the stock airbox. Apparently Rich ran the 12.4-12.5 times with catless DPs, summer tires (explains the 1.7 60' times), as well as the CAI. He said that once he installed the Corsa exhaust, it dropped another 0.1 seconds. I wonder how much of that is attributed to the CAI if he was able to get comparable times with the stock airbox in the first place?
I'd also love to see some datalogs of those running Airaids to see how their STFT looks at WOT and whether it resolves the anomaly of STFT dropping like a brick above 5400 RPM.
Are they now including the revised weatherstriping or do we need to perform our own mods?
Has anyone removed parts of the weatherstriping from the hood that surround the Airaid at the front and not just the snorkle port? I saw BPD1151's pics and he only removed the striping in front of the snorkle and kept the second strip intact. It seems as if you removed part of that second strip (the one that surrounds the hood sensor) it would open up the intake to more incoming air.
FoMoCoSHO said:So are you saying you think airflow is choked at 5400 for the stock box?metroplex said:Thanks! That link helped a bit, but the modified Airaid doesn't seem to offer much of a power gain over the stock airbox. Apparently Rich ran the 12.4-12.5 times with catless DPs, summer tires (explains the 1.7 60' times), as well as the CAI. He said that once he installed the Corsa exhaust, it dropped another 0.1 seconds. I wonder how much of that is attributed to the CAI if he was able to get comparable times with the stock airbox in the first place?
Is that anomaly at all boost levels or does it change as you crank it up?
I thought I read something over in HPT world saying that meant your airflow model was off a bit...I don't remember if they said more or less than expected.
That was the exact statement that was related to me a few yrs ago but they were still kind enough to send me a taller blade at no cost since i purchased the intake directly from them. Zmetroplex said:The latest from Airaid is that they no longer suggest/recommend the longer blade weatherstrip and claim it doesn't exist in their inventory. They also said the weatherstrip's purpose is not to seal the airbox to the hood, but rather act as a gasket to prevent the airbox from rubbing a hole in the hood liner. Yet, their website for the CAI kit clearly said the airbox is supposed to seal to the hood.
metroplex said:I ran 11 psi and saw the STFT start dipping at a bit higher RPM (5700? RPM) and actual lambda starts to get a bit richer as well but the magnitude wasn't nearly as much when running more boost.
If using a CAI changes the STFT behavior with the same tune, one could conclude the stock box is a restriction at higher RPMs. K&N claimed their panel filter in the stock box is limited to 750 cfm because of the small airbox. I'm sure at that flow rate, the restriction might be fairly high.
metroplex said:FoMoCoSHO said:So are you saying you think airflow is choked at 5400 for the stock box?metroplex said:Thanks! That link helped a bit, but the modified Airaid doesn't seem to offer much of a power gain over the stock airbox. Apparently Rich ran the 12.4-12.5 times with catless DPs, summer tires (explains the 1.7 60' times), as well as the CAI. He said that once he installed the Corsa exhaust, it dropped another 0.1 seconds. I wonder how much of that is attributed to the CAI if he was able to get comparable times with the stock airbox in the first place?
DSD TIP after conversion for BAROmetroplex said:Are you targeting a desired TIP of 15.0 psi (about 29.5 psi TIP) or at the MAP?
I tried 15 psi at one point and didn't see a difference in the RPM range (drop occurs in the 5400 to 6200 RPM window).
