SHO making an "warped rotor" sound but brakes are fine... Wheel bearing?
Strange but I get that kind of sound every now and then on my 2013 SHO.  Coming to a stop I get a grinding type noise on the right front side/brake.  Now it doesn't do this all the time but it's still there and I have 20k miles now.
Strange in the fact that my Taurus Interceptor does the same thing.  I thought Ford had a TSB or bulletin on this somewhere in the world.
There is a TSB for rotor/pad grinding sound, a quick summary is here:  http://www.shoforum.com/showpost.php?s=e994fbc368d053022a8ad9663dc12ceb&p=1217965&postcount=1
To quote:
TSB 10-17-3 concerns Front Brakes Intermittent Grunt or Grinding.
Models affected:
Taurus and Taurus SHO Built on or before 28 Jul 2010
Taurus SHO w/PP Built on or Before 10 Aug 2010
The fix: If your model has the noise the fix is to remove and replace the rotors, pads, and anchor brackets. THE PADS WILL NOT BE REPLACED on the SHO PP, just the Rotors.
The Part Numbers:
BB5Z-2001-A Brake Kit except SHO PP
CB5Z-1125-A Rotor
BB5Z-2B292-D Right Bracket SHO
BB5Z-2B293-D Left Bracket SHO
BG1Z-2B292-A Right Bracket SHO PP
BG1Z-2B293-A Left Bracket SHO PP
Preceded by 11-05-15
