I changed my plugs last night using this thread as reference. Went fairly smoothly with one hiccup. The rubber boot attached to the bottom of the coil was my issue. 4 out of 6 stayed on the plug. The first one being the passenger side by the firewall, aka the most PITA one to get at. A pair of long needle nose pliers are definitely required to get the boot out. After ripping apart the first one with short needle nose pliers, I borrowed a long one from my Dad. I was then able to get a good hold and pull then right out, completely intact. I went to Ford first thing this morning and got a new one, plus 2 extras just in case. Here's a pic. They were only $2.45 each.
Here's a pic of it attached to the bottom of the coil.
Since I have big hands, thus making it extremely hard to work in tight spots, I moved the strut tower brace to gain a little more room. Just remove the 4 nuts and slide it forward out of the way. Or you can take it completely off, but I didn't do that. Here's a pic of the driver side, passenger side the same.
Finally, even though I had no issue getting the stock plugs off, I still used anti seize on the new ones.
Once I had everything put back together, I started her up and she purred like a kitten.
Brad
2010 SHO with PP
MyCal LMS Stage 3
Sent from my iPhone
Brad
2010 SHO with PP
MyCal LMS Stage 3
Sent from my iPhone
