PokerMunkee said:
Can't stress this one enough! Also, I'd recommend to have a warm engine (not super heat soaked or cold soaked) as you reduce the risk of damaging anything.
The coil on plug pack screws, tighten to just 62 lb-in, not much is needed there as well.
I removed the foam insulator for the fuel injector pump (the big cylindrical foam thingy on the front) to give me more room. Those stinkin' clips gave the most trouble, it is a two-action disconnect, you pull the red tab down, then push down on the clip and pull out. (SOUNDS EASY RIGHT??)
For the rear (right hand side plugs), Believe it or not, you can reach them with a mid extension + plug socket back there, it is just a reach.
Those dang connectors, I swear!
Also the large black tube that travels from front to back on the driver's side (I believe that is the CAC system), I disconnected the front end of that to give me some play room so I could reach those rear spark plugs a bit better).
Good luck!
