So the radiator hose I used was strong enough to hold it in place with very little movement, it didn't really rest on the AC lines.
same here. i have a very small section of hose tho. the pipe makes most of the bend and is a pretty rigid setup . . plenty of clearanceStealBlueSho said:So the radiator hose I used was strong enough to hold it in place with very little movement, it didn't really rest on the AC lines.
BOT_ROCKET said:So I'm trying to decide how to mount this on my FuSpo and I'm not sure if I the route I'm planning is the safest. My current plan is to simply make a steel t-pipe and splice it into the middle of the rubber hose. Is it safe to cut that hose, or will cutting it compromise the integrity of the hose? I plan to fab up a custom intake system, but that is probably a ways out.
BOT_ROCKET said:I *think* I could cut out the section that I've marked in red and have enough straight hose to get clamps on there. I've created my own bead roller out of a modified wire crimper. I also picked up an exhaust pipe cutter so I can create my own pipes with good beads.
I'm pretty sure if I mount the valve close to the pipe there should be room. I think this weekend I will pill the hose off and get some measurements so I can start a custom pipe. That way I wont have to worry about cutting the hose.
I suppose that would be the preferred method so I can return to stock if needed. I'm sure buying a factory hose like that costs roughly one million dollars.
Linemonkey said:Quick question. What is the diameter of the dump tube? I found several like this, on ebay, with the vband already welded. Would this work?
http://m.ebay.com/itm/Universal-Stainless-Dump-tube-Flanged-for-V-Band-for-Tial-MVS-38mm-Wastegate-/262830922805?nav=SEARCH
Sent from my SAMSUNG-SM-G930A using Tapatalk
