FoMoCoSHO said:
wasinger3000 said:
Found some knock.
How I'm getting it at 35% ish I don't know.... only thing I can think of is the fuel just won't mix right.
Its not the fuel, mine does it too. I think its happening under heavy throttle, coupled with an abrupt lift. I need to redo my data logging parameters and try to pin it down. Its not dangerous at all for us but could be for the guys running straight gas. Consider only A6's motor came apart under that same circumstance. It also explains why some of us have noticed throttle response going away under spirited heavy off-on conditions.....the car is seeing knock and goes into self preservation mode.
Well that's good to know. I might have to ease off the throttle after a wot run.
One thing I've been thinking about is this, if I have a meth kit and if at some point I floor it to pass and the meth doesn't spray because of a mechanical failure will the car be able to pull enough timing to protect it? to Or will I be picking parts up off the road.... that's the one thing that keeps me away from meth right now.
